Zenith C27V22 27" TV Logo
Anonymous Posted on Aug 18, 2013
Can't get visual and audio on screen from dvd player
Anonymous
Level 3:
  • Master 379 Answers
  • Posted on Aug 18, 2013
Anonymous
Master
Level 3:
Answers
379
Questions
0
Helped
106386
Points
1009
No audio on burned dvd
what you use to Burn DVD, here is the one i use.
This DVD Burner can Convert and create DVD from various video and audio files for extensive visual and audio enjoyment on any DVD players.
The screen is constantly white from the time I turn it on. I have audio but no visuals. The player is brand new; I have not even used it yet.
I have run into the situation when I took a brand new player apart and not all the cables were plugged in the board. Since yours is brand new it needs to go back to the store for exchange, if you take it apart the warranty will be void.
1helpful
2answers
How do I hook up a DVD player to a proscan 32 inch flat screen tv?
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
Mistracking on dvd player
Hello!
It turns out there is a problem using hdmi cables with integrated amplifiers Denon dvd players (the 1940 series) - the hdmi cable processes the visual signal before the audio signal. Therefore there is what appears to be a lip syncing problem because there is a short 'time delay' between the visual and audio signals. I would advise anyone to simply use an AV reciever as they incorporate time delay technology so the visual and audio signals are in perfect sync. Luckily, Richer Sounds, where I bought the intergrated amp gave me a full refund, no quibbles or hassle. I would like to add I am unsure if the problem lies with just the Denon 1940 hdmi dvd players and intergrated amps or ALL hdmi players. Also, I was trying to achieve a simple 2 speaker set up with the amp.
The forum on What Hi-Fi document this problem with much better clarity and technical explanation that my understanding of the problem. However, the lesson learned is, if you want any speaker set up with your dvd player, use a dedicated AV reciever.
Best Regards, Graeme Young.
2answers
Pictue but no audio on VHS playback..VHS record to DVD visual/no
Hi
please check the format settings, maybe the audio is not in good settiongs!~
Thanks!
2helpful
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
My dvd recorder will only play audio and not visual when I try to play dvds
check the spindle motor,set your tester to x1 if normal the reading is 200ohms if not change your spindle motor,if not fix the problem replace the MPEG board of you dvd.
Dvd gpx
Try switching your audio cables, you may have them in opposing slots.
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
