Garden Logo
Anonymous Posted on Aug 17, 2013
Cant find location of spring - extension part# 932-0556 on model #135Q695G372
mickey813
Level 3:
  • Master 472 Answers
  • Posted on Nov 08, 2013
mickey813
Master
Level 3:
Answers
472
Questions
0
Helped
215154
Points
1078
Not sure if you need the part or were it gose can ya tell me what yor looking for
How to put the spring assembly back together on model GMT180XC
Dear Hendrika,
I have done an extensive search, and I can find no car or truck with this model number.
Please share the make, model, year, and mileage of your vehicle.
After that, tell us which spring assembly you are working on.
God bless your efforts.
Pull cord on briggs & strtton wont retract back
If you don't know how you will need a manual, it is kind of tricky.
Remove the rope. Feed the spring from the outside of the housing and connect to the recoil housing. Turn the wheel using a 3/4 " rachet extension and the spring will feed ito the housing until the end of the spring connects to the ouside of the housing. Keep turning until the spring is tight, back off about 1/2 turn and feed the rope from the outside, be carful here, if the extecsion comes out the spring will uncoil and you get to start off all over again.
5helpful
Cub cadet LTX 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
1helpful
I have a LiftMaster garage door opener.When the door closes it is not completely closed on the right side. It has about a 1/4" gap at the bottom. It starts closing evenly but when it is about 2 feet...
It sounds like a door spring problem. Here is a website with a video of adjusting a door with extension springs.
http://www.diygaragerepair.com/Extension-Springs-s/296.htm
1helpful
2answers
Have 1/2hp garage door opener that will not open the door. If the remote pad battery is dead will the opener stop working? if I press the remote opener the door move about an inch stops and the light...
Dead batteries will not cause your problem. If it is the main light flashing 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. Tweak them a bit to make sure.
Long drive belt cant remember how to put spring back on
The 'j' hook hooks over the transaxle and just hangs there. The spring attaches to the stabilizer rod (reference # 43) and the other end attaches to the "j' hook hanging on the left axle.
Jun 20, 2009 • Mtd Garden
New dryer belt is rubbing top of idler arm spring
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page look for "Dryer Belt Diagrams" under the Special Features section. There is an extensive list of dryer belt diagram illustrations available that you can print out. Maytag is listed. Hope this helps you.
Nov 11, 2008 • Dryers
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
