Question about Refrigerators
Refrigerator I have a GE Refrigerator (1999) Model No TBG18DAYJRWW. The fresh food compartment gets too warm. I then empty the freezer compartment, remove the back cover and the defrost coils are frozen solid. I manually defrost the unit and it runs perfectly for 3 weeks. Then I have to repeat the above. I have read the various articles and have narrowed the problem down to 1 of 3 components. The defrost thermostat The defrost timer The heater. When I look at the defrost coils there are 2 defrost thermostat units (L55-30) components. Why 2? and how do I determine which one is defective? Where in the refrigerator would I find the defrost timer? Thanks, Liam Devlin
  • 4 more comments
  • Anonymous Nov 14, 2007
    I have the same problem my one stops working because it is frozen solid and its a frost free. I then defrost it and works for a while then does the same again. What can I do?
    Wayne
  • rafaelanaya Dec 13, 2008
    Freezer coil is making ice and lowe part of refrigerator is not cooling.
  • Anonymous Dec 28, 2008
    The temp inside the refrigerator is 62 and i've reset the temp - but it's only getting warmer and the ice box seems to be working just fine
  • Kustomford Jan 07, 2009
    I have a beverage cooler the gets warm, I take the top cover off and it is frozzen solid. After it all melts the cooler will start working again for about 3 days..
  • Richard_R_Da Mar 23, 2009
    I have the same problem, except mine is a Sansung. The freezer side is working fine, but the fresh food side will either be at the correct setting, or at about 53 degrees. This unit is running a single compressor, but claims to have separate condensers. Can anyone help. This unit is in Mexico and about 150 miles from any access to any technical help.
    Thank for any comments.
  • bkmantra May 13, 2009
    Freezer works but the lower area gets cool but not cold like it should and drips water at the back of the top shelf.
    New Friend:
My Haier wasn't defrosting right, ice would build up & the freezer would be fine but the fridge temp not right. After reading lots of posts, defrosting a few times,etc., I took advice & ordered a new defrost timer. (Repair Clinic) They had diagrams that showed where things are. This is everything I did. Unplugged it, cleaned off everything in back, double checked fans were all working, drain pan draining, in freezer took off panels to make sure ALL ice buildup was melted including drain hole. Made sure everything was connected (there is sensor w/clip that could be near or on the condensor coils & it wasn't on - so I made sure it was on) - dried things, put back together. Changed the defrost timer. Plugged back in. Two weeks have gone by and things are just fine! You definitely need to completely defrost the fridge because even if the defrost timer is the problem all the ice built up won't allow the fridge to defrost in the defrost cycle. You'll want a fresh start & it's worth it! I thought we were going to have to buy a new fridge! And my husband is proud that I did the trouble-shooting & repair all by myself! Thanks to all the help I found online!
Posted on Dec 10, 2009
    Novelist:
  • 87 Answers
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
6ya staff
SOURCE:
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Maytag bottom freezer Model MBF2254HEB not blowing cold air into freezer or fridge, blows warm air if blowing at all, starts and stops. Any suggestions? Possibly a reset button somewhere? Thanks - Kurt
Aug 29, 2009 | Refrigerators
Working fridge, warm freezer.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge doesnt stay cold
Aug 28, 2009 | Maytag MZD2766GES Side by Side...
Left door open while cleaning out refrigerator and top unit shut off freezer is still on what should I do
Aug 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works refrigerator doesn't ge tbx-25zle
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
Jun 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fresh food side warm. Freezer works fine.
I think you are short of refrigerant, needs to be topped up and checked for leaks.
Mar 03, 2009 | Samsung RS2534 Side by Side Refrigerator
Freezer coils freezeup fresh food side gets warm
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FRESH FOOD COMPARTMENT TOO WARM
it could be a defrost heater problem . the heating cycle is not defrosting the ice that is why your having frost build up. the heater could be damaged, thermosdisc damaged, electronic timer module damaged.try thawing it up by unpluging it for a day or two until there is no more water dripping at the back then try it again, im sure the refrigerator section would cool again for a week or two before it wouyld go back to the same problem. dont forget to bring back the setting to 5 for freezer and 35 for refrigerator in order for the thermostat to work.
Feb 04, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
1,695 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
