High pitched noise from inside the TV when the picture comes on
Hello randapaint,
This might be from the IHVT (Integrated High Voltage Transformer), or more specifically a short in the IHVT causing it to arc, producing the high pitched whine, you are hearing. Take the back off of the TV and try to detect where the sound is coming from, more then likely you will notice it coming from the section that contains a large component with a large red cable coming from it, to the top of the CRT (picture tube). Replace the IHVT (with the exact same model) if it is bad.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
