Unfortunately this sounds like more than a blockage. If this was a blockage water would not drain, maybe fill in sink or dishwasher etc. If water is coming from walls probably means it is leaking from drain pipe in the wall. Which would mean opening wall to find leak.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
SOURCE: HI Dear water from dishwasher is leaking from
there is a cloged line between the air gap and the disposal (if you have one) or the drain under the sink.
you will need to remove the pipe and flush out with water. this is usually a rubber hose. most of the time, the clog is at the disposal where the rubber hose connects.
you should be able to see the clog once you remove the rubber hose. clean this out ( I use popsickle sticks) once cleaned out, reinstall the hose and try your dishwasher.
SOURCE: Water hammering after disconnecting a washing
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
