SOURCE: Door not closing properly.
take door off and pack bottom hinge with washers. make sure hingebrackets on cabinet are tight. however, door hanging a bit should not really affect sealing. if seal is gapping, one solution is to warm with a hairdryer and pull outwards gently
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
SOURCE: Creda W120VW Intermittently not starting when door is closed.
I don't know if you are still having a problem with your washer, but a new door lock is needed to put it right.
SOURCE: our fridge door won't close properly
The door hinges have nylon bushings/washers to help them work smoothly. If the unit is very old and had a lot of use (like a large family) the bushings or washers could be just worn away. This also is indicated if the doors seem to be misaligned. If the doors don't seem out of place, it could just be that the unit is not sitting on a level surface, causing the box to twist and the doors th therefore bind.
Other possibilities: The door is burdened heavily with the milk, juices, food, etc. and therefore is just plain heavy. You have a "water-thru-the-door" unit and some leak has occurred to fill the door and it's insulation with water. (eww!)
Check to see that the surface is level, and that the door fits correctly. Make replacements or adjustments as necessary. Lighten the load on the door, or fix the leak.
If you find my suggestions to be helpful, please share with us some
details so that others may benefit from knowing the whole story.
Thank you!
