SOURCE: plastic rectangle part of the door lock of bosch
that whole piece is part of a switch. you must take off the front panel to fix. not a easyfix if you dont know how.
SOURCE: Bosch Washing machine WFP 3300 Fault
Hi F01 is a low water pressure error and is caused when the
washer won't fill water, check the water inlet valve if that is fine and there
is no clogs in the inlet hose then the water level switch/pressure switch
should be replaced. Hope this helps...please post back for further assistance. Daniel
