Previously the main light on the garage door opener worked fine. Model is Sears Craftsman 139.53629SRT. One of the leads that connects to one of the door opening sensors got severed so we had to manually operate the garage door for a couple days until I could repair the connector at the sensor. After turning the power back on (circuit breaker) upon completing the repair (it was left on before I made the repair), the garage door functioned perfectly through all remotes but the main light (which worked prior to turning the power off) would not come on. I removed the front panel and all connections appear fine. I've tested the bulb and it is fine. I also tried to use the "learn" function explained by someone else here with a similar problem and that didn't work either. Any suggestions are appreciated. Thanks!
after the garages door opens the light does come on.?
I'm sorry about your light not working right. It seems weird that it isn't turning on at all when the door opens. I can't think of why that would be an issue. I know that there are some professional garage door repair companies, have you called giving any a call. Good luck! https://dieseloverheaddoors.com/services...
