Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My freezer control in my ge side by side refrigerator is stuck
My side by side refrigerator freezer temperature control is stuck in #5 and the motor doenst stop running.
steyr1
Level 2:
  • Expert 148 Answers
  • Posted on Apr 05, 2009
steyr1
Expert
Level 2:
Answers
148
Questions
Helped
85455
Points
450
Change the termostat that control temperature . is burned out. you need new one.
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 • Freezers
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
1helpful
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
1helpful
I have a GE side by side refrigurator model Gss201epc ww serial Tf220054 and am having a problem with stuff freezing in the crisper, I do not see any type of adjustment any ideas here? Thanks
initially, set the refrigerator compartment control at 5 and the freezer control at 5 and allow 12 hours for the temperature to stabilize.
Several adjustments may be required. Adjust the controls one increment at a time, and allow 12 hours after each adjustment for the refrigerator to reach the temperature you set.
Adjustable Humidity Crispers and Snack Pan (on some models)
HIGH LOW
HIGH LOW
Normal
Coldest
Slide the control all the way to the High setting to provide high humidity recommended for most vegetables.
Convertible Meat Pan (on some models)
The convertible meat pan has its own cold air duct to allow a stream of cold air from the freezer compartment to flow around the pan.
The variable temperature control regulates the air flow from the freezer compartment.
Slide the control all the way to the Low setting to provide lower humidity levels recommended for most fruits.
2helpful
3answers
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
It will not defrost..the mother board ,the defrost thermostat,and the heater have all been changed..
Sounds like the # 4 and # 5 freezer thermistors need changed . The # 4 , is the 1 " torpedo looking piece , clipped to the top of the coils . The # 5 thermistor , is located at the bottom of the freezer section at the bottom of the rear panel , with 2 white wires going to it . Still a 1 " torpedo looking piece . The # 4 , tells the main control board , the evaporator temperature . The # 5 , tells the board , the freezer temperature .
2helpful
Variance in freezer compartment temperature
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Top Admiral Refrigerators Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
