Sony 46 KDL46EX520 LCD TV Logo
A
Anonymous Posted on Aug 09, 2013
Colored vertical band across top of screen sony kdl46ex520 lcd
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Mar 27, 2008
SOURCE: SONY xbr screen problem
It sounds like one of your circuit boards may be going out. I'm sorry I don't have a better response than that.
Anonymous
  • 320 Answers
  • Posted on Oct 18, 2008
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Anonymous
  • Posted on May 26, 2009
SOURCE: Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
Anonymous
  • 30 Answers
  • Posted on Aug 09, 2009
SOURCE: SONY KDF E50A10 vertical multi-colored lines across the screen
bad Q box, need tech to replace
roety
Eric Rotmil
  • 587 Answers
  • Posted on Oct 24, 2009
SOURCE: thin vertical line runs across the top of screen
Hi my name is Roety,
I can help you with your issue ,
 Try the format, aspect buttons on the Box remote, if the line is there on every input and effect the TV menu your panel (screen) is bad.
A new panel would cost as much as a new TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SONY LED TV Vertical & Horizontal Lines on the Screen
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
I have same sony model, I have problem with vertical lines on LCD Screen, When i power recyle and switch on the TV, i can see the clear image , After on mintue and half the image fade and i can not see...
Unless you are really good in TV electronics, there is really no simple solution...the transformer for the video screen is heating and shorting out. I hope you have a warantee or guarantee on it!
2helpful
Signal degradation across vertical section of
This appears to be a common complaint on LCD monitors. Some LCD screens have control issues.
An LCD screen is the panel and a bunch of Line control chips wrapped around the outer edge. A problem with one line top to bottom or left to right is almost ALWAYS the LCD panel itself.
A problem with a fixed band (The band is in the same place at any resolution) is often the LCD but might be the signal driver chip (A large plastic pack with about 100+ leads). A person with a VERY small soldering iron might be able to resolder it, but they MUST know what they are doing. (board must be heated, lead free solder, eye like an eagle...)
If the band moves around or changes width, it is the signal chip or the power supply to it from the power board.
It can be software if there is a firmware upgrade. This takes a shop.
Brownish band across top of screen
Please press the WIDE button on the remote repeatedly to remote the Bands. If the issue persists, you may need to change the Aspect ratio to 4:3 on the Video source that you have connected to the TV. Check the link for more info:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C308757&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=130649210&stateId=0%200%20130647809
1helpful
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
4helpful
Sony bravia LCD KDL52 TV: blurred picture with color bands
It is most likely the TCON board (located at the top right against the LCD panel). When these boards have problems, they can act up when cold or warmed up.
You will want to check with any extended warranty company you might have, or Sony's part website for the availability of the TCON board.
The problem here is, sometimes those TCONs are not made available separately and need to be replaced with the screen.
If you have to replace the panel, buy a new tv. You'll save yourself a costly repair.
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
4helpful
3answers
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
2answers
Re: Kodak Troubleshooting
The screen is purple with wiggly vertical lines. I'm going on a trip tomorrow. Help!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
