Try moving your drain hose to a different height.t may need lower than you have it. My washer did the same , Drain hose needs to be higher than the pump that drains the washer.
The hose drains to the trap under the sink, about 1/2 height of machine, there are no other options
The discharge hose sometimes not long enough to get th right height you need for proper operation. I use and old vaccum hose to attached to my discharge hose to get the height I need for the machine to operate properly. Use duct tape toonect the two hoses ( if you move and don't need as much hose you can get them apart) then get a screw in type hook to hang the hose about 1"-1 1/2" above the back of the washer, ( without tension on the hose) then place the hose back in the trap under the sink. If you have a basement , look to see if you can try adding a PVC SCH 40 Y or T to the main sewer line above the Y or T you should add 1 to 2 foot section of pipe ten connect a U (trap) then another 2 to 3 ft pipe for discharge hose to connect to. Pending where your main sewer line is located to where the washer is, that will determine how tall the drain pipe will need to be. Have you checked the fault codes & manual for a solution?
SOURCE: indesit W93 washing machine
We have W124, it allmost completed renewed inside. Thanks 3 years warranty and new service engineer, motor was changed and then all problems disappeared.
SOURCE: Washing Machine not draining
same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
SOURCE: indesit washing machine fills up and starts cycle
Could be heater. Try machine on rince cycle.Not pressure switch. If mahine works on rince then chances are heater. But this should not affect spin
