Yes, I changed the filter and held the reset button for 3 seconds but the red light remains on. Older model fridge. Maybe the button's stuck?Yes, I changed the filter and held the reset button for 3 seconds but the red light remains on. Older model fridge. Maybe the button's stuck?
You can't post conmments that contain an email address.
This is another one for the user manual! Always check it first. It would seem likely that the system is either time or water flow controlled. By this I mean that somehow your little red light is caused to light up. For example by a little device which can measure how much water you've used. This device could need resetting.
on most maytag /jen-air. products if you push the light and the lock together to reset the replace filter light .. hope this hepled mm ( Majic **** ) thanks for using fix ya
Hi and welcome to FixYa. I am Kelly. Here is what to do:
Maytag and Jenn-Air - press and hold the lock and light buttons (lock and water on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.
Hopefully that resovles your filter light being on.
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Thanks, Sea Breeze
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
If you want complete service manual please let me know, Oh Please rate Me, Thanks, Sea Breeze
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air Press and hold the light and lock buttons until the change filter light flashes. It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks. Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Water Filter Status Indicator Light (select models)
red, it will remain red until function is reset. To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
