SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
SOURCE: peg perego john deere powerpull tractor will not run
could be the gears hold unit of gound and push pedal try to hold wheel if it stops gears are worn..best way to test it id say would be by pass switches 1 at a time let it run see if it does same thing if it dont theres your problem
SOURCE: Have a PerPerago John Deere Tractor. The shifter
If it is new, contact Peg Perego for a replacement. If it is not new, you can upgrade the shifter to a better version. (I just upgraded the one on my kids' gator.) You can buy the upgraded shifter for $24. http://tigerimports.net/sunshop/index.php?l=product_detail&p=7095
SOURCE: tractor won't go in low gear or reverse
I had the same problem and replaced the shifter which I found at
http://www.mypegperegoparts.com/switches.html.
This fixed all the speeds and now it runs great.
Hope this helps
