I believe that would be in the contol switches, latching relays, or the pilot servos. Solenoids that supply pilot pressure to the main shift spools.
lso you may have a bad ground or bad connection on the shift controllers themselves. Chech to see if there is power at the swiches. Then hook to pos. batt. terminal to check for power through the ground terminal at the switch.
Please post to fixya.com if it does, so I get the credit for the solve. Let me know if you do need more advice. Good Luck!!!
Hope this helps and good luck. Please post to fixya.com if it does, so I get the credit for the solve. Let me know if you do need more advice. Good Luck!!! Comment
