Timex Mid Size Sports 1440 Coach Black Nylon Strap Watch Logo
Anonymous Posted on Aug 06, 2013
How to remove the alarm setting - Timex Mid Size Sports 1440 Coach Black Nylon Strap Watch
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Aug 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
288
Points
39
Press reset plus start.
HOW TO SET ALARM
In the Alarm Mode, use D to scroll through the alarm screens until the one whose time you want to set is displayed.
2. Hold down A for about two seconds until the alarm time starts to flash. This is the setting mode.
3. Press C to move the flashing between the hour and minute settings.
4. While a setting is flashing, use D (+) and B (-) to change it.
  • When setting the alarm time using the 12-hour format, take care to set the time correctly as a.m. (no indicator) or p.m. (P indicator).
5. Press A to exit the setting mode.
To test the alarm
In the Alarm Mode, hold down D to sound the alarm.
To turn an alarm and the Hourly Time Signal on and off
1. In the Alarm Mode, use D to select an alarm or the Hourly Time Signal.
  • When the alarm you want or the Hourly Time Signal is displayed, press A to toggle it between on and off
  • The alarm on indicator (when any alarm is on), snooze alarm indicator (when the snooze alarm is on), and the Hourly Time Signal on indicator (when the Hourly Time Signal is on) are shown on the display in all modes.
To stop the alarm
Press any button.
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • 0helpful
    I am trying to get out of army time for my digital wrist watch, and there is an alarm that keeps coming off that I don't know how to stop. I'm not sure of the brand...i bought it at Wal Mart about...
    Your watch should have a "mode" button (often at 8 o'clock) and this enters the settings menu so that you can change them. keep pressing the mode button until you reach the setting you want to change.
    You should be able to find a setting that says something like "24". Experiment with the remaining buttons to change the setting. The display should change to "12".
    Press the mode button to find the setting for the alarm (Often abbreviated to "AL" or "ALM"?).Again experiment with the buttons to either remove the alarm or or change it form "ON" to "OFF".
    Changing the values of the setting is often done by pressing the 4 O'clock button but if this does not work, try the one at 2 O'clock.
    2helpful
    My husband would like the alarm off. i don't know how i did it but i set the alarm. please help me remove the alarm setting. thank you.
    * Press the MODE button until you are in ALARM mode
    * Press STOP/RESET (-) or START/SPLIT (+) to cycle through alarms
    * When you have selected the alarm you wish to erase, hold down STOP/RESET (-) to clear the selected alarm
    3helpful
    2answers
    NEED THE INSTRUCTIONS FOR AN AQUALITE 100 [email protected]
    To set time:
    1) Press "Mode" button until Time is displayed.
    2) Press and hold "Lap/RST" button until seconds display starts flashing.
    3) Press "ST./STOP" button to change selected entry.
    4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
    5) Press "Lap/RST" once you are done to set the time.
    To set Alarm time:
    1) Press "Mode" button until ALM is displayed.
    2) Press and hold "Lap/RST" button until minutes display starts flashing.
    4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
    5) Press "Lap/RST" once you are done to set the alarm.
    To toggle alarm sounds on and off:
    2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
    3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
    7helpful
    2answers
    Coleman wristwatch - alarm and chime keep beeping
    Hey, I had the same problem with my Coleman watch. It would alarm at midnight. I used the mode feature like the poster before me said. When I got to the alarm "screen" I used the button that backlights the watch's screen. The light came on and the alarm feature was removed. I hope this helps.
    Mar 12, 2010 • Watches
    5helpful
    Lost instructions for Lexon world time clock model Planete
    to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until
    the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally,
    press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
    To set main display, press and hold "set" until the hour begins to
    blink; press "adv" repeatedly until hour AM or PM is correct. Now
    press "mode" so that the minutes blink, and use "adv" to get the
    minutes right; then press "mode" so that the next item begins to
    blink; use "adv" to advance until it is correct, then press "mode"
    so that the next item blinks, and so forth until you're all done.
    Finally, press and release "set".
    Aug 10, 2009 • Watches
    Remove alarm schedule
    go to each alarm and press the upper button on the left side to disable the alarm
    20helpful
    2answers
    Alarm
    So the alarm setting is just hidden. To unhide it, just go to the time menu and hold set. With the flashing time, scroll through the menus with the mode button until you get to alarm 1. Then press start/split to unhide it. You can also hide or unhide any of the other menus along the way.
    Top Timex Watches Experts
    Paul Bade
    NOEL
    NOEL
    Ngoro
    Are you a Timex Watch Expert? Answer questions, earn points and help others
