Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower Logo
A
Anonymous Posted on Aug 05, 2013
Electric mower hum but no start - Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower
Dan Apthorp
Level 3:
  • Master 2,824 Answers
  • Posted on Jun 28, 2016
Dan Apthorp
Master
Level 3:
Answers
2824
Questions
0
Helped
889660
Points
7391
Sounds like your motor could be burnt out.
Mower will not start. replaced battery and starter coil. turn key and it makes a huming sound
If motor is frozen the electric start motor will hum and burn out if it cannot turn of the gas engine.
1helpful
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
Can i fix small electric motor
Most electric motor problems are caused by the bearings failing. Before that happens it may get very stiff but stil turn. With the power off, and the blade still attached, try turning the blade at least half a turn. Is that possible? Any noises as you turn? Is it very stiff or fairly free? If you turn it several times you may find that putting it upright and connecting the power it may start turning again.
Let me know what you find.
1helpful
Electric Starting Difficulty on Toro mower with Tecumseh engine
it sounds like to me that the starter pully is getting caught up on the worm gear ,this could be because of dirt or grass getting in the way make sure that no grass or dirt is around the worm gear
Mar 03, 2010 • Garden
1helpful
My B&D mm525 electric mower won't start.
Motor brushes are wearing out.
Aug 27, 2009 • Garden
The blades wont engage when the button is pulled to start them.
If the mower drive belt is extremely loose the spring that holds it tight may have broken,check to see if it is broken before you replace the belt
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
