Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
jamie w craig Posted on Aug 05, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hydrostatic what weight of oil goes back into hydrostatic
mickey813
Level 3:
  • Master 472 Answers
  • Posted on Nov 09, 2013
mickey813
Master
Level 3:
Answers
472
Questions
0
Helped
215280
Points
1078
10/w30 should be ok
What weight hydrostatic oil is recommend for tuff torq k46, and quanity
Try this site. Lots of info and pix. Site says 5w-50 synthetic oil.
1.85 liters
How to do an oil change on Tuff Torq K46 transaxle
Sep 19, 2017 • Garden
John Deere 430 lawn tractor hydrostatic transmission will not work in forward or reverse even with no weight on the axle. New filter and oil did not fix. What should I check next?
Some have a procedure for "burping" air from the hydraulic system. Changing engine oil and filter won't affect it- independent system.
Have a craftsman LT1000 Riding Mower 17HP. changed the oil in the transaxle and now can't get the automatic forward and reverse to engage. Any suggestions? !
get it off the groud rear wheels put a weight on forward drive if it works fine if not with the weight still on start turning wheels by hand if it work let run like this 30 minutes if not did you use the right fluid not transmission fluid if you did buy new hydrostatic pump buy one any way pumpsounds like bured up 200 dollars for pump before you do this isworth it if mower over 4 years buy new mower you will save a lot of money in long run
Aug 24, 2014 • Garden
3answers
How many quart of oil does if take for a change ?
I think for your mower it is 48 oz. You should have a tag under the hood to the right that lists all the common replacement stuff and part numbers for them and quantities. There at the bottom of the list I think is the weight of the oil (30W) and the quantity (48 oz I think). It has been a while since I worked on one like yours though, but I think that is how they do the Husq.
2helpful
What weight oil goes into the gear box? whats the proper weight oil for the motor?
30 weigh oiltdetergent (if available,if not regular 30 weight oil will perform also), as for the gearbox.transaxle for the tines use 80-90 weight gear lube
While using my Craftmas 17,5 hp lawn tractor with a snowblower attachment, the hydrostatic drive seems to loose power, especially when it working hard and after its been in use for a while. I don't think...
My name is Dane and I'm going to help you with your problem. First, I believe those craftsman units are sealed and there's no way to actually check the hydrostatic oil level. So the first thing to do is make sure that you don'thave any leaks around the transmission assembly. If it looks clean and oil free, I would venture to say that it is more of a 90% chance that your drive belt is the problem, however it isn't from icing up, but rather from the heat of the extra work from the weight of the snowblower, causing it to slip. The belt isn't all that expensive and before I would get excited and start worrying about transmission failure, I would just replace the belt first, and rule it out. Make sure all your pulleys and tensioners don't have any loose hardware, and look alligned.
I think you'll fix the problem though just by the belt replacement. I hope I've helped. Thank you! Dane
5helpful
2answers
What kind of oil do I use in a Wheel Horse lawn tractor?
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Jun 24, 2009 • Garden
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
