More information is needed.
Brick wall is inside apartment... what is on other side of wall?
Open existing electrical box. Drill through back of box and drill through wall until you come out on other side of wall. Install new box #1 on wall where drill comes out. Run conduit over to another new box#2. Drill through wall again until you come out on inside brick wall where you want to relocate original box. Install new surface-mount box#3 on brick wall. Then run wiring from original box. Original box cannot be bricked over or covered with building materials since it is a junction box where wires connect.
Other option is to install extension ring on top of existing electric box. Run conduit across face of brick wall. Install new box#1 where you need outlet.
Other option is to chisel away the brick and mortar from existing electric box down to floor level (or over to door frame). This will allow recessed conduit that can be concealed with matching mortar. Then run conduit across to new location. Cover conduit along floor with baseboard, or chisel out brick along floorline to accommodate conduit, then mortar over conduit. Or simply paint conduit to match brick. You must use conduit since wires cannot be run openly.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
