Garden Logo
Anonymous Posted on Aug 03, 2013
Wen electric chain saw
Will other 14" bars for wen work with my hornet?
Bill Boyd
Level 3:
Top Expert:
  • Garden Master 53,816 Answers
  • Posted on Aug 04, 2013
Bill Boyd
Garden Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925882
Points
172802
Take your bar along and compare If all the holes line up then there will be no problems with any bar that is 14''long
2 Related Answers
Anonymous
  • 583 Answers
  • Posted on Aug 25, 2009
SOURCE: Correct replacement chain
take the old chain with you when you go tobuy the new one is the best way
Testimonial: "Thank you for your advise, that will help."
Anonymous
  • Posted on Nov 07, 2012
SOURCE: tighten chain on WEN 5041 electric chain shaw?
First loosten that 1/2 bolt on the bar--the lookat the bar when it goes into the housing you will see the adjustment screw.Tighten the chain by turning the screw when you get it to where you want it then tighten the 1/2 inch bolt
WEN HORNET MARK II 14 inch Electric Chainsaw Model 5014. Show me how to tighten chain. When I pulled it tight now I need the adjustments to the tighten it more how do you do it?
Question edited for full 'make model (what it is)'.
Question moved to Chainsaws.
If you have used up all the adjustment on the bar, you MUST buy a new chain. It has worn or stretched and is about to break.
https://www.google.com/search?q=5014+electric+chainsaw
Mar 27, 2022 • Garden
1helpful
Tighten chain on WEN 5041 electric chain shaw?
1helpful
Remington 14" Electric Chain Saw Assembled 1.5 Peak: I just wanted to know what type of oil to put in t...
I have been using regular chainsaw oil and I think it works ok. I inherited one of these and would like to find a spare chain and also a manual. Can you give me any info? Thanks
Tim
2helpful
2answers
Need new chain for wen saw 5014
It is here N;
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Select "Wen; 5014; #DriveLinks; All; All; All".
#DriveLinks, the part of the chain that fits in the bar groove. Match the number with the fourth column to get bar length.
The above results are for an original or equivalent bar. Only YOU can determine your level of expertise, how much risk (read the triangular warnings - the OE chain was probably green) you are willing to assume and choose one of part numbers listed. Once you make your choice it can be found on the Internet or through local merchants (no shipping and handling fees). If the local outlet does not handle Oregon your choice can easily be converted to a part number of the manufacturer they do handle. I suggest a few phone calls to save you time and gasoline. Given the Oregon part number and your assurance of a purchase, if my store, your chain would be waiting when you walked in the door.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Hello, I am trying to find a user manual for my husband's latest bargain find...a Wen 10'' electric chainsaw - Model 5010 - has Hornet Mark 1 on label - also, where can I go to purchase extra chains for...
How about one slightly newer (6018)? I was not able to find a match for your model. Wagner purchased Wen some time back and have since stopped production.
WagnerSprayTech
http://www.wagnerspraytech.com/portal/finding_a_product_manual_spray,98115,747.html
If you take your existing chain to a local chainsaw seller/mechanic a replacement can be fabricated. No chain? take the entire saw and bar.
Your can create a part number here:
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
I came up with "91VG041G" HTH
Lou
Dec 09, 2009 • Garden
Where can I find a new chain bar adj screw for WEN 3818 gas saw?
Most older chainsaw adjustments are visible when the saw is viewed from the end of the bar back to the saw. More modern ones are near the bar nuts (side). Lou
1helpful
Aug 25, 2009 • Garden
13helpful
4answers
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Top Garden Experts
Jay Finke
Jay Finke
john h
