It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
Remove front cover on the genset and you will see the brushes and rings. Clean the rings if black with emory cloth and inspect brushes. Flash the fields by apply a 12V battery to the brushes. the brush closest to you or the bearing is connected to the positive side of battery and the back brush is negative. You have to do this with genset running. You should notice your voltage climb up to over 50Vac maybe even over 100Vac. Make sure to use rubber gloves when flashing fields and keep hands away from rotating parts. if voltage does increase when flashing the the voltage regulator is shot. If voltage does not climb then you will need a new genset or generator end.
Flash the fields. Remove front cover from the generator end. You will see the brushes and rings on the rotor. The ring closest to you is positive and the ring closest to the rotor windings is negative. With a 12 volt batttery and the generator running, place the positive side of the battery to the ring towards you and negative to the back ring. Make sure to use jumpers and keep fingers away from rotating parts and don't get zapped. You should see output voltage increase. If it does, your voltage regulator is bad, if it doesn't your generator end is bad.
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
sounds like you need to "flash the field". This means you've lost you excitation voltage for the generator to produce electricity. In most cases you need to get a 9volt battery and connect it to 2 & 6 inside the generator. They are Blue & Red wires, but they are not the only blue & red ones there. The generator should be running and the battery should only be connected for about 5 seconds. This is very dangerous because of all the high voltage and democrats.
I work on these everyday. You most likely have a bad rotor or stater if the starter engages while running and no output. The no out put is making the generator think its not running causing it to try and start. If its not that then its the control board or voltage regulator.
youve checked breakers or fuses?
