A handheld steamer uses hot steam to relax the fibers in clothing. A jet of steam is directed at the cloth suspended on a hanger. A steam wand at the end of a hose is held a short distance from the cloth - providing a smooth look without the application of scorching heat to the clothing.Steamers are ideal for soft and delicate fabrics like silk, satin, polyester and jersey. Because a garment steamer does not actually touch clothing - there is little
I have a hand steamer and use it every time I wear a garment that's a wrinkle-magnet. Usually it does the trick but I may have to steam it for five to ten minutes. Floor steamers that are often used in department stores have a larger capacity water tank and tend to be the most effective. But they also cost a lot more than a hand-held steamer.
The steam not only removes wrinkles, it freshens the fabrics - making them look cleaner. You can use this steamer on clothing, bedding and table linens and also to remove.
Sorry to hear that! The burnt plastic smell indicates that the element over heated to a point that the heat radiation melted the substance. The internal heating element has shorted out and took with it vital accessories necessary for normal function of the steamer. Too many parts have become inoperative and the cost of repair is excessive. The only solution is to replace the streamer. Do not plug the defective unit into a live power outlet for safety reasons.
The problem is the thermostat (NC 150 C). A replacement is available at Digikey.com, item R2015025 (part no. 317-1468-ND) It's a simple replacement with the bottom removed.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
