Nothing happens when I push the start button on my Gas Dryer
I have a Whrilpool Estate TGDX640JQ2 gas dryer. When I push the start button nothing happens. It completed a dry cycle and when I tried to start it again nothing happens.
Re: Nothing happens when I push the start button on my...
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If you are having problems with your gas dryer not heating
the most common problem is that the ignitor goes bad. Even though it glows
sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different
things that can go wrong causing the dryer not to heat.
try turning the drum by hand...is it jammed? if not, then:
the motor will not turn due to a number of reasons:
1.) simply burned out copper windings
2.) switch not turning on motor or not turning on motor starting circuit-depending on design
...if jammed, then try to find the interference to turning
The plug to the door switch came unplugged. Quick fix. Thanks
