Hello!
Most likely, error F 25 means that the aquasensor, the turbidity sensor of water, has failed.
Possible reasons of this error:
1) Perhaps there was a clog in the system of draining the water. Dirty water does not merge and because of this the sensor shows muddy water. It is necessary to clean the drain filter;
2) Lime or scale on the turbidity sensor. Always use high-quality washing powders or add descaling agent
3) Dirty water got into the plumbing. Drain all the water and run the wash program in hot water. The washing machine should be empty.
SOURCE: Washer's tub will not move
I don't know what the E5E error code refers to but I can think of at least one possible reason for no motor action, even if motor itself is ok and board has been replaced. The relay itself could be faulty with no power from the output side, even if it clicks on. Less likely but still possible would be a faulty overload protector at the motor.
SOURCE: Kenmore Quietpak4 washer
is bearing ok in rear shell no drag when belt it on knot in a bind will check around
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
SOURCE: I have a Kenmore HE2T error code F24
The "F24" error code is a heat sensor error code. The following link explains the error code in detail and the steps to correct it:
http://www.fixya.com/support/r1976126-f24_error_code_whirlpool_duet_kenmore
In many cases, the connector plug on the NTC sensor wiggles loose and causes the error code. Check the NTC connection first to make sure it is tight and making good contact. This may save you a service call and/or replacement parts. Make sure you UNPLUG the washer before servicing anything inside the unit.
A replacement NTC module (if required) can be purchased at searspartsdirect.com for about $10. Refer to the parts illustrations under the "Tub and Basket Parts" heading.
If you have any questions, please let me know. I hope this helps you.
NOTE: Each washer comes with a technical data sheet located inside the cabinet. You will need to remove the lower toe panel directly below the door to access it. If it is not located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all troubleshooting tips, wiring diagrams and fault codes with explanations.
SOURCE: Washer will not run, Kenmore HE2 Plus, Model# 47532601
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
