How to fix indesit washing machine wixl 105 It is suddenly stopped washing with the power button flashes red fast and two more buttons flashes green and door doesn't open and cloths still in waterHow to fix indesit washing machine wixl 105 It is suddenly stopped washing with the power button flashes red fast and two more buttons flashes green and door doesn't open and cloths still in water
AnonymousMar 15, 2014
You can't post conmments that contain an email address.
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Just sorted this problem out, wife said just b4 leaving for work,oh love the door on the washing machine wont open and theres a red light on,,OMG i thought, as she said she would find the instructions when she gets home, so i got the corless drill out and a big hammer,( not needed,) lol just turned the power off and after 2 mins the door unlocked and was able to get all the clean wifes undearware out, cheers all and hope this helps
Try turning off the machine at the plug for about 10 minutes or until the light on the machine disappears, then try to open the door. Usually works for me.
Usually indicates door is not closed properly.
If it is shut securely, and still does not work, then you could have a faulty door lock.
Another possibility is the control unit could be faulty.
What is the model # of your washing machine?
IWDC6125
