My fossil Big Tic has the seconds counting in the background. After the battery was changed, now the minutes are counting in the background. How do I get the seconds back?
I think you have a number missing from the model number, they are all 4 numbers as opposed to 3. If you purchased it on Amazon or eBay, it is a clone. Contact Fossil and book it in for a service.
Inside the case back on my JR-7855 is a label with the steps to take to change the batteries. The sticker says to short the pad marked "S1" with the pad marked "+". Keep doing it quickly, then check the watch face. You got it right when the seconds start to change on the face.
Here is a view at the inside of the watch. The two points you are looking for are highlighted in red.
your watch has two batteries inside, the small battery is the one that had to be replaced. it is under the big battery, the small battery makes the minute and hour hand move while the big battery makes the seconds flashing. i hope that i had been helped you.
(click on this link to go there) and you will see some instructions for various big tic watches and you can select the one that suits yours.
The only one that I could find that had a single button above the winder used it to cahnge the colour. Pressing this button for 2 seconds will change the colour to "alternating" and the same again will produce a fixed colour. Perhaps this will make the change of display you need.
Often with watches, you need to use a pair of tweezers to short the battery case to the chassis ((often marked "ac"). This seems to be a re-set function, although I have never found an explanation for the need to do this.
If all else fails, look up their contact details and speak to them about your problem.
