My problem is that my computer cannot start normaly
When you boot the computer or put it on a writen will appeared on the screen saying that we apologized with what happen but windows do
not start successfully a hardware or software might be intercorrupted
if you do not know what cause the problem click start windows normarly but if the computer has been goin on andyou want to save your setting click safe mode network then down you will see safe mode, safe mode, safe mode network, start windows normarly and beneath start windows normarly it will tell you to alight your choice until windows can start in seconds but each time i tried to click either on windows start normarly or safe mode network the computer will load until it went off or restart
to the same promlem (computer type sony laptop)
Re: my problem is that my computer cannot start normaly
My friend virus has eaten away some file which can enable windows to start and so your operating system is corupted and what you need to do is to is to re-install new or repair. or the bus cale may not be recorgonising the hard disc, chech and try again
this could be four things, firstly the cpu heats up above a comfortable heat ands its internal safety shuts it down, that is what i would put my money one, the second could be faulty ram, the third would be blown bios and lastly a faulty power supply. but its normaly 1,4,2. in that order
You need to start up in safe mode you do this by pressing F8 while it is booting up you will then see a screen that says start normal or safe mode pick safe mode if it boots up and it will take a little while then shut down the computer by selecting shut down and then restart this will most likley solve your problem
go in bios and disable the on boot password and if tha blue screen appear again write down the error that is writen on that page and search on the net for it.
If it works fine with one stick of ram. Then it is the ram that is incompatible. You can try different settings but you may end up that the stick isn't compatible. Hope this helps let me know if you have any other questions. Thank you, Lee
Complete the recovery again but leave the discs in the computer. That way if the computer needs some files while rebooting it will take them off the cd....if not it will load and that will be the end of that. Just remember when you boot the computer for the first time to initiate the recovery, when it says to boot from cd touch any key...that is only done one time when you first initiate the recovery...after that do not touch any key if it says that...just let windows boot on it own. Once windows boots on its own, then you can take the recovery disc out and put it away.
It is becasue of your computer is not properly shut down and so your harddisk has some bed indexing of memory location.
For that you need winxp disk or recovery disk.
Then boot your computer with that disk .
You have to set first boot device as your cd or dvd rom.;
For that when you power up press F1 or F2 or "del" key to enter in bios .
Then go to boot option then sewt first boot device as your cd or dvd rom.
then save settings then put winxp or recovery disk in rom.
Then follow the procedure .
Then enter in recovery console then type in prompt "chkdsk /r"
then it fix error on harddisk.
Sometimes this command fix eror and then after restart windows load normally but sometimes need to repair windows.
So after check this if still face issue just chose "r" when it finds your previous version of windows then it recovers your windows.
The blue screen that you see is what they call "the blue screen of death". The error that you have is Unmountable Boot Volume. This is caused by the operating system not being to load due to hard drive errors. This happens due to the computer being shutdown improperly or hard drive problem. I suggest that you contact the manufacturer of the computer so they can try and restore the computer without formatting or changing the hard drive.
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
That message will appear when there is no boot record found on any device the system board tries to boot from. This probably means that your hard drive is not being detected, does not have a bootable copy of Windows on it, or is defective.
Make sure the drive is correctly listed in the motherboard setup screens. If it is not, check for proper power and data cable connections at both the drive and main board. If the drive is being correctly identified, you may need to reinstall your operating system.
