F2 fault code relates to the fridge section only, which has stopped working. The freezer section is still working fine. Anyone know how to solve this problem?
F2 Is fridge evaporator sensor faulty it will require new sensor part no.7323301
Hard to believe.. sensor is rarely faulty unless it will be a really old freezer (e.g. 20 y).. mostly it is not indicating the right temperture and then the indicator flickers with F2 on the display. You should start with defrosting the freezer section only for at least 48 hours.. it even took 3 days for mine to defrost totally... it now works again :)
miele kfn 8462 s top freezer refrigerator is displaying an F1 fault code
F2 code means the condensor is frozen and is not incidcating the right temperature.. you should defrost your freezer for at least 48 hours with open doors, even thought it is a no frost freezer... i had the same problem.
