Washer turns on and flashes code dL F
FdL
Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Or lock failure. Probably a bad wax motor. get ahold of your authorized dealer. This is a defect on these machines. They have a new and improved wax motor. Raise enough hell and they will fix it for you.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I'm having the exact same problem & can't run my washer. I'm about to lose it. Any thoughts?
how do I check the switch assembly and CCU? where is all this located?
