Need info for 1991 Pace Arrow RV: (1) where is hot water heater; (2) how do I access the hot water heater; (3) how do I fill with water????????? Heater runs on propane. Gas detector is working & light is green. We just bought the RV, but no owner's manual. No prior experience. Need advice, help, info, anything to help us get hot water running in RV. Cold water not a problem. Got plenty of cold water.
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Make sure outside shower water hot and cold are turned off also make sure Thebes water bypass is off
No hot water inside 2005 pacearrow. heater seems to working - had hot water when traveling w/pump - when hooked to outside hose only cold water/.
LP Alarm goes off for not reason??
[email protected]
light is flashing fast at a staedy pace
