Toshiba 37HL67 37 in. LCD HDTV Logo
A
Anonymous Posted on Sep 05, 2017
Need screws/bolts for pedestal assembly
I moved from one condo to another. At my former condo I had the Toshiba 37HL67 37 in. LCD HDTV attached to a wall mount. I left the wall mount at the old condo. I want to use the pedestal assembly but cannot find the screws/bolt for the assembly. Please help. Thanks in advance, gene johnson [email protected] 360 904-9413 July 19, 2013 at 5 PM pdt
5 Related Answers
Anonymous
  • Posted on Dec 09, 2008
SOURCE: What must I do to attach a Wall Mount to my Toshiba 20HLV16 LCD Chassis?
Attach a wall mount, to back of a 32" sharp, LCD flat panel
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Aug 14, 2010
SOURCE: what size bolt do i
Metric M5 or M6 from HD or LOWES for about 35 cents each.
Get different length to try.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Anonymous
  • 30 Answers
  • Posted on Nov 29, 2010
SOURCE: how do I install the pedestal stand for the
the stand just slots into the bottom of the tv and you just tighten it with four bolts provided.
Anonymous
  • 234 Answers
  • Posted on Mar 21, 2011
SOURCE: What size bolts attach tv to stand for Toshiba 37"
You will use the bolts that you take out to remove the base from the tv.
The_Go_2_Guy
Ben
  • 41 Answers
  • Posted on Sep 12, 2011
SOURCE: Need to know the bolt
The wall mount specifications are 400mm x 400mm
Need the size of the screws in back of the tv to attach to the pedestal.
IF YOU HAVE USERS MANUAL SIZES SHOULD BE IN THERE IF NOT EMAIL LG AT THE ADDRESS FOR YOU COUNTRY OR YOU COULD TRY PHONING .
Remove pedistal base from 24h898 aoc envision tv
You need to remove the cover that hides the 4 screws that hold the stand to the monitor. There are 3 pieces to the pedestal base. The base plate, the pedestal, and the screw cover. To remove the screw cover, look on the back where the pedestal attaches to the monitor. There is a cover just above the pedestal. Pinch the top left and top right sides (about one inch from edge) to unclip the cover. Remove the 4 silver screws (2 on each tab) and put them in a ziploc bag to avoid losing them. Tape them to the pedestal/base and cover.
1helpful
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn [email protected]
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
28helpful
2answers
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
4helpful
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
5helpful
How to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
