Question about Dishwashers
Miele G575 Dishwasher
Hi, The dispenser flap on my Miele G575 dishwasher not infrequently fails to open at the correct part of the wash cycle. As a result the powerball detergent is not released and the wash needs to be repeated. Apart from that the unit works perfectly. Would a new dispenser solve the problem? Doccy D
  • 1 more comment
  • janettel Feb 07, 2008
    I have a Miele G892 and I noticed for the first time that the soap dispenser never opened. Any ideas?
  • DisgustedInd Feb 24, 2008
    We have the same problem. Half the time the flap doesn't open and we have to re-run the load. The dishwasher has also gotten much noisier since the first few quiet months of operation. We're very disappointed in the product and the poor service we've received in trying to fix the problem. A repairman replaced the pump and motor but to no avail.
  • Doccy D May 10, 2008
    Dear all
    Thank you for the tips. Below is the definitive solution!
    We eventually had to have the Miele Service man out. The problem was
    not with the door at all, but was caused by blockage of the water ducts
    in the rotor. This resulted in eratic spinning and, apparently this
    effects the door opening. Don't ask me how!! Anyhow, he cleaned the
    rotor and, behold - problem solved. That was several weeks ago!
    Doccy D
    New Friend:
If the water level is not adjusted at the right level
(see Miele G 575 manual page 29),
the flap doesn't open at the right circle,or doesn't open at all.
(Cause of the low water level the machine makes more noise!)
======Now shut down the power for the machine!!!=============
To adjust the water level new,you have to open the shield(2 screws) under the
main door.(enginen compartment).(You don't have to move the machine!)
On the right ,right,right,hand side,there is a 6 cm round beige plastic box.
(the first thing you see to you right and very easy access)
Only one black water hose(about 1cm=1/4inch) and a few wires are going into this box.
This is the water level adjustment box.
In the middle of the beige plastic box is a beige plastic screw
to adjust the water level new.Turning it clock vise ,increasing
the water level.
(For the right water level,see page 29 in your G575 Miele manual)
The water level hasn't to be super price.Just in about and enough.
(It seems that the rubber membrane in the water level unit ages
and therefor it has to be readjusted after a longer time)
Posted on Feb 06, 2012
  • Martin Bauer Feb 11, 2012
    Stop,stop stop!
    I made a mistake.Don't touch the adjustment box.
    99% reason why a Miele is not working properly anymore
    is the water level.If the water level isn't reached the pump
    is sucking air, therefor the water pressure is dropping down.
    Without enough water pressure the flap won't open and
    heat won't start.
    The water passing resistance in your Miele increase by
    the time because you have sediment in your water.Also
    in the ionizing tank(salt water tank and resin filter)could built up after a longer
    time alga which slow down the water pressure.
    This is not a reason to throw your Miele away.
    Miele are made to work 20 years.
    Solution:You have to connect in your dial timer pole H6 with B6 with
    a wire.
    (You have two H6 pols and two B6 pols.)
    (There's a wire plan inside the door.)
    Don't do it if you can't do it properly!
    Always shout down power by pulling the plug!
    (to put the dial switch on 0 is not enough)
    This wire connection is double the time in which water can flow into the machine.
    My machine is now working like a new Miele.
    I found this "trick" in a German forum.
    You should also check the filter right in the beginning of
    your Miele hose.Therefor you have to unscrew (by hand)the hose
    from the house water tap.If you look inside the fresh water hose of your
    Miele ,you can see a small filter for sand inside.
    If it is dirty, you can pull it easily out with a pair of pliers.
    Clean it and put it back.
    Check at the same time the house water tap if it is giving still
    enough water and pressure.The tape could be slowed down
    by sediment over the years.
    a kind of algues that increases
  • Martin Bauer Feb 12, 2012
    Sorry,I made again mistakes in my writing
    and I don't know how to correct it.
    Correction:"If the water level isn't high enough,the pump sucking air."
    and instead of" hose water tab" I meant" faucet".
Watch also for how you load the upper rack. The flap opens inward and the rack has an opening to permit full opening. If this is blocked by your dishes, the flap won't open properly.
Posted on Dec 18, 2007
    Chief Leader:
    An expert that has 500 followers.
    Leader of the Pack:
    An expert that has 20 followers.
It could be jammed with old and hardened dishwasher detergent which dries like cement, preventing the little door from opening up. Clean the soap dispenser area with warm water and a toothbrush, especially underneath the area where the cover springs open.
Posted on May 09, 2008
It is caused by not enough water being allowed in by the 'flood protector'. You know, that weird lump on the inlet hose at the tap.
Mine has been slowly getting worse and worse. Seems it needs good water pressure to open the flap and it can't achieve it unless the correct amount of water is in the washer.
Currently I just chuck a couple of pans of water in at the start and again at 32 minutes for the rinse.
Posted on Apr 22, 2008
6ya staff
SOURCE:
We have a Miele G 870 SC dishwasher. The soap dispenser always opens properly to dispense soap if we run the Economy cycle, but it always stays closed if we run a Normal or Intensive cycle.
I would certainly check with the repairman and have it checked. It is possible that a connection may have been missed since the new dispenser was installed.
Oct 02, 2017 | Miele Dishwashers
My g575 miele dishwasher will not fill with water until the end of the dry cycle.. help
see this possible fault:Water-inlet valve
the valve is defective, test and replace it see how.
Float switch
had been fail, replace see how to test it, and see the diagram
Jun 09, 2012 | Miele Dishwashers
Water levil to high on miele g575
It is possible that there is a block in the drain hose which prevents water from previous wash to fully empty.
This means when you start dishwasher next time it overflows and causes the dishwasher flood switch to trip and shut dishwasher.
You will need to check the drain hose for any blockages and clear it.
Mar 11, 2011 | Dishwashers
The detergent flap does not open
Check the dispenser for easy close & open. Trouble could be- latch relay not getting energized- wires might have snapped - relay driver - command not reaching from the controller etc.
If you check all the points you will get an idea. I feel micro-controller may not have any problem as other cycle is OK.
Further assistance contact the authorized service center.
May 22, 2010 | Miele 24 in. G665 Built-in Dishwasher
My Miele dishwasher does not get the plastic refridgerator items dry
Hello Zipmap0202,
I have never found that plastic dries very well in my Miele dishwasher as well.
Check your rinse aid indicator to see if it is on. Next to the soap door there is a door you can add rinse aid to. There is also a dispensing control knob that allows you to turn the amount of rinse aid dispensed up or down. Try changing the setting and see how that works. I have done this and it has not worked well for me. I find opening the door after the cycle is done (Just cracking) it will dry plastic alot better
Sep 16, 2009 | Miele Optima G2430SCi Stainless Steel...
Miele G660 premier dishwasher
There is a solenoid that opens the door to the dispenser. You can check it with a volt/ohm meter. Sometimes large dishes can block the door keeping it from opening. I personally know on some Whirlpool washers (because it was mine) that if the bottom drawer is put in backwards, it wont let the door open. When I opened the main door, then the dispenser would flop open. You need a meter to check this part if its not the other things. Without it, you are just guessing.
Mar 15, 2008 | Miele 24 in. Novotronic Premier 500...
Miele G575 slow and insufficient water fill
The unit has a double valve system, the waterproof, it could be that one of the valves is not opening fully. They can break down over time. This would mean you need a new one. This should fix the problem.
Open the door once the wash has started and check the water level. It could be that it is siphoning out half way through the wash. Make sure your drain hose is secured up properly.
If when you open the wash and there is not enough water, it is most likely the waterproof, as I stated before.
cheers.
Sgt 48
Oct 30, 2007 | Miele 24 in. G656SCi Plus SS Built-in...
Dishwasher Miele G575
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Regarding the screwdriver adjustment- This is the rinse aid dosage adjuster. To obtain the best drying results,use the selector on setting 5. When dishes show spots, set it to a higher setting. Turn lower if dishes are cloudy. Good luck!
Sep 13, 2007 | Miele 24 in. G665 Built-in Dishwasher
Miele G575
This sounds like the overflow trip switch has been activated. Some time back I had this problem with a Miele G664. The service man undid 4 screws on the door and removed front panel and found water in the drip tray, He then checked the pipes, outlet pipe had a pice of plastic bread tag stuck in it , this was slowing down the time it took to empty the water and the next fill made it overflow and switch off the dishwasher. He cleaned out the chanel on the overflow that was full of dust and fluff checked the levels to make sure the dishwasher was sitting true. Closed it all up and ran the dishwasher. Perfect!
Bill $160. It did take him the best part of an hour and I live a long way out of town.
Apr 30, 2007 | Miele 24 in. G656SCi Plus SS Built-in...
Dishwashers Logo
60,164 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
