Hi, I have installed a Maax Iris B 3 piece shower. Followed the instructions (although most = useless).The shower leaks in the bottom corner of the fixed panel, between thw abs wall unit and the aluminum brackets that hold the fixed glass unit. I have since siliconed the sh#t out of all vertical seams (but not the inside track, as per instructions, but I still get drippage. Anyone with suggestions?
SOURCE: leaking maax shower drain
try this:
you might but it will depend if it is pvc then yes any other material you might be able to use a waterproof epoxy but it will harder to repair because of the epoxy but the pvc you can prime and glue the seam from the inside..
SOURCE: No instructions in the tub doors
Solra,
This might help you out.
http://www.maax.com/en/TechSupport/InstallManuals.aspx
Feragola
SOURCE: Assembly instructions for Niagara corner shower encloser
Go to this link and print the pages. original instructions. Good luck.
SOURCE: hi we just bought a maax breeze neo corner shower
There will be a nailing flange on the walls of your shower. Typically, drywall screws are used on this flange on the top portion and along outside edges spaced 6-8" apart. Use a high quality tub/shower caulk down the seams.
SOURCE: Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
