I replaced the belt. Thanks for the solution. The real problem seems to be the drain pump. It was running noisy. Then it froze up. I think. When facing the wheel, it turns freely when I spin it clockwise. It will only spin counterclockwise about 1 turn and then it clicks to a stop. If I turn it clockwise less than a turn, I can turn it back about a turn counterclockwise. The motor spins counterclockwise. The agitator wheel will move the tub if I turn it counterclockwise. I take it the drain pump is broken (I think). That is what I am inquiring about for advice. Am I correct? Also, I would also like to know what happened. I would like a perspective before I buy the pump. First of all, what happened? Am I correct in that it should turn counterclockwise? Or am I assessing the situation incorrectly? Thank you. MikieM
