Cars & Trucks Logo
Amy Leary Posted on Jul 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have cracks in the stucco on my house, how do I patch it?
Stephen
Level 3:
Top Expert:
  • Cars & Trucks Master 21,873 Answers
  • Posted on Jul 11, 2013
 Stephen
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6207800
Points
67230
This is the car and truck section, but I can tell you there are products on the market for repairing stucco. Much the same as plaster repair.
You can check online or at one of the big box home improvement stores.
2answers
Water leaking into garage after heavy rain
I would say you need to fix the wall first wnd seal the ingress of water, then when dried out thoroughly, re plaster.
How can I replace some stucco that has fallen off my house in the simplest way possible (i.e. does not have to be perfect)?
Hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this at reliable-store
they can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
How do I fix a crack in my driveway
In an asphalt driveway, cracks are often caused by water that has seeped underneath the surface. With increasing and decreasing temperatures, the water contracts or expands. Fixing cracks can be done using fillers but before starting the actual work.
First make sure that the area that needs fixing is smooth and clean. The fillers or patching product will not stick well in rough areas. Remove all debris from the crack using a brush and then a powerful air gun to totally get rid of all residue and loose particles. Don't forget to wear safety goggles when cleaning to protect your eyes.
For small cracks, you can apply the filler using a caulking gun but if you don't have one at home, you can simply pour the filler into the crack. Be careful not to get fillers on areas that don't need repairing since the filler can leave stains on your driveway. For larger cracks, those more than two inches deep, pour the filler little by little, first filling up to the first two inches of the crack.
You can avoid cracks in driveways by installing driveway grids from Ecodeck & Pond Safety Ltd. Visit their website to learn more.
How do you fix peeling stucco on exterior of house.
Scrape everything off that is loose. See if there is any damage to the surface underneath, ie. rotted wood -cut it out & replace it. Spray the area with bleach if mold is present & dry. Once you have repaired the surface, coat it with bonding agent(cement area at Lowes or Home Depot) blue is better than white. Now get a bag of stucco and replicate the pattern of the surrounding area.(not easy) Stucco can be troweled on, splattered on, sprayed on, painted-on and in a huge variety of thicknesses. You may even need to trowel a base coaton to even out the surfaces to the surrounding area before you apply the finishing coat. When choosing materials take water proofing into account. Water damage is the usual culprit to stucco loss. Providing a better surface than what was originally there is recommended. Good luck.
The case that holds the thermostat is cracked
This would be called a thermostat housing or cover. It is not impossible to patch but water is erosive. I would use J-B weld.
I have used J-B on a pump housing for a 3500PSI pressure washer and it still works. But there were not constant hot and cold stresses as you have in your engine.
I have a little crack in my water housing outlet in my 97 olds achieva can I patch it with anything
You would be better off replacing it. You should be ale to find them or order one from your local parts store.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2answers
Could I patch a crack that is in my water outlet housing
Most water outlet housings nowadays are made of a thermoset plastic resin material that can be "etched" with a dremmel tool to make the crack accept some epoxy material such as JB Weld (excellent material when mixed exactly per directions) and cleaned with isopropyl alcohol prior to application. A warm hair dryer follow-up is recommended to "flow" the material into the etched crack. Allow to cure overnight (24 hours is best). A similar procedure can be done with mnetallic castings such as in older 70's and 60's vehicles with similar results. The parent material MUST be thoroughly cleane to do a good job!!
Coolant leaks from the plastic housing that the thermostat sits down into.
You may have to remove the thermostqat housing and replace the O ring that is the seal. Otherwise the housing is cracked and needs to be replaced or repaired with an epoxy patch. Hope this assists you. 3ef2f06.gif
1helpful
2answers
Gas smell
This is a nasty problem with this car. It is the smell of mostly Sulphur. It comes when the Catalytic Convertor gets faulty. Replace it and get Smell-free. Thank you Sir, Have a nice day.
1helpful
My windshield washer reservoir leaks on my '98 Honda Civic.
Ok... put the duct tape down. And back away from the truck... just kidding.. I wouldn't recommend duct tape. or hot glue...
If you have a visible crack or hole, drain the tank to below the crack, clean with a little vinegar and water, and lightly sand the plastic housing.
Place a small patch of plastic sheetrock mesh tape over the crack and then...
Use a bit of epoxy that is recommended for use on plastics. Mix up a small batch, spread over the crack and over the mesh.. Let dry and refill.
Don't worry about pressure, because the tank isn't under pressure on most cars...
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
