There seems to be a short or loose connection to the touchpad
It will work if you hold down the button while it is cooking
If you don't -it stops working after several seconds
A good whack on the control side of the oven makes it work
sometimes. The oven itself heats and works properly.
The oven is 4 years old.
I can only toss you some ideas, but likely but not always, you might have what are called security screws holding the cover on the microwave - they typically have a little pin in the center and you need to buy a special tip to remove the screws including any on the side - then pull and slide the cover off the microwave - Needless to say with the power unplugged!
Then you should take a close look even with a magnifying glass, at any of your connections - many are spade connectors pushed onto flat blade-like pins - you may find that you have an over-heated one, or a loose one. If it is overheated, you will have to cut off the bad connector, get a new one wherever, strip the wire(s) back and crimp on the new one. If the connector is simply loose, take a pair of needle nose pliers and close up the connector so that it goes back on tightly.
Now this is where you need to (sorry to swear), but use common sense - plug in your microwave with the cover off, and try you touchpad to test whatever repair you did - If it is fixed, then unplug and put the cover back on and back to Zip-Zap and Ding Suppers
Eric
SOURCE: GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
SOURCE: Touch control failed on GE Spacemaker Microwave HVM1540
If you want to order a touch pad, (it has the micro computer built in it!) and fix it that way, you'll still have a 2-3 year old machine.
I would say it would be quicker and cheaper to buy a new one.
SOURCE: GE Spacesaver Microwave touchpad
You almost certainly have a bad membrane keypad.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
If you would like to
have us
do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for
some GE models, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame assembly which comes with a new keypad.
In this case, you simply
move your circuit board into the new frame. That is a simple do-it-yourself
job.
Either way, we can let
you know what your options and costs would be and send you other
helpful info.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
We're happy
to help you. Once we have all your information and
offer a final solution, we'd appreciate your
thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer
my PVM1870sm1ss shut off when I touch any cooking key-not clock
I bought it 6/2008
