My u line wh95tp-03 ice maker will no longer run. it trips the breaker almost immediately when turned on. any suggestions?
Something that powers up immediately, try any cooling fans or the solenoid. Easiest test is just disconnect anything non essential and turn on, if it doesnt trip, turn off, connect one thing and try againn. then connect one by one until it trips again and the last thing you plugged in will be faulty.
SOURCE: Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
SOURCE: water line to ice maker frozen
Check to make sure that the damper between the freezer and fridge is not broken or frozen open. Make sure that you shut off the water supply to the fridge until you get this fixed because the line could crack and then you could flood the house.
SOURCE: GE GSS25LGM Ice maker
Our Ice maker quit working. Won't make ice, but will dispense water. I unplugged the refrigerator and plugged it back in. I noticed that the green light on the ice maker is now blinking. It was steady on before I unplugged the fridge. Any ideas?
SOURCE: No water to the ice maker
Yeah, the valve is definitely not turned on. Just turn the valve and you should be good to go...
SOURCE: LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
