American Standard Colony 2388.012.222 Linen Two-Piece Round Front Toilet Logo
Posted on Mar 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water comes from bottom of tank when commode is flushed. I have a two piece toilet, upon flushing it water pours from in between the two joined parts-tank and commode.
Gregg Rene
Level 2:
Sniper:
  • Expert 86 Answers
  • Posted on Mar 27, 2009
Gregg Rene
Expert
Level 2:
Sniper:
Answers
86
Questions
0
Helped
92447
Points
316
You need a new tank gasket. It is a rubber piece that seals between the tank and the bowl. They are fairly inexpensive and if you have patience and a little plumbing know-how; they can be changed at home. Here is a good on-line set of instructions:
http://wiki.answers.com/Q/How_do_you_change_the_gasket_between_the_toilet_tank_and_the_toilet_bowl
1 Related Answer
Anonymous
  • 170 Answers
  • Posted on Mar 29, 2009
SOURCE: Water comes from bottom of tank when commode is
Ok the toilets work is that the tank reservoir is where your fresh water....is stored....and the flush valve...(if you take the tank lid off you will see that the handle is either connected to a chain or uses a lever to lift something called a flapper....it is usually black but it can be gray..or blue...also there is a flash valve that is a long tube and a round bottom with a rubber gasket...that seals the flush water into the tank...reventing it from entering the bowl.......when you lift the handle water dumps from the tank...into a s-shape tunnel called a trap...(this is in place to prevent sewer gases from entering the house the water sits in the bottom of the trap acting as a seal against smells...gas...etc...from the sewer line....Now your tank is mounted to the bowl by (2 or 3) bolts that you can see and access from inside the tank...however the person doing this will have to also reach under the toilet where the tank mounts to the bowl and hold a pair of pliers or a crescent wrench on the nuts which hold the tank in place.....after these are removed...the tank will lift off of the bowl.(now obviously the water has to be shut off and be disconnected from the tank....when the tank is lifted ...a small amount of water may spill out ...but it is clean water...so no worries....since the tank and the bowl are made of porcelain they obviously would not seal just sitting on top of each other so the tank...has the bottom part of the flush assembly which is mounted to the tank by way of a large plastic nut extends out of the bottom opf the tank 2-3 inches......around this is another black or gray about 3-5 inches in diameter...and costs less than $5 at Home Depot.....change this out, reassemble and your back in business. Be advised that the flapper in the bottom of the tank...if you ever have to change it out and the tank gasket you are going to change out (after a long period of use or just time and deterioration)...leave black residue on your hands...if you handle them...but it is safe and easily washed off...it just may freak.. a layperson out....so one may want to use some gloves they can toss afterwards....Any other questions....and I can absolutely answer them in regards to toilets...as i have repaired and or replaced 2500 - 3000 in my 35 years in the apt/home maintenance industry.
I hope this helps.....thank you for rating my effort...and good luck....tha Fang.
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
OCCASIONALLY HEAR SMALL LEAK COMING FROM BOTTOM OF TOILET...WATER BILL UNUSUALLY HIGH...(FAINT HISSING SOUND)
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl through the flush valve slowly...causing the tank to drain and the fill valve to run every few minutes or so. start by inspecting/cleaning or replacing the flapper and hopefully that will do it because a one piece toilet flush valve needs a special wrench,to remove it, that you use with a ratchet. If you buy a new flush valve, it comes with the wrench (glorified piece of plastic) and is not too difficult to get the flush valve out. you can get a replacement at http://www.plumbingpartsdepot.com/ They do mail order, too. All you need is the toilet type - a four digit number embossed in the tank starting with a 2. hope this helps but if you need anything else just ask:)
We have a san raphael one piece toilet, and it sounds like the water is running at intervals. Sounds like there is problem with water level. What can I do to correct this problem? John
Sounds like the flapper is leaking water out of the tank. The flapper is the rubber valve that comes up and down every time you pull the flush lever. It is located in the tank at the bottom in the center. Very cheap part to replace.. Just turn the water off to the stool, take the top of the tank off, hold the flush lever down until all the water is out of the tank, reach in to the tank, disconnect the flush chain from the flapper, and disconnect the flapper arms holding to the stem. You can buy a flapper at any hardware store even at wal mart. Hope this helps.
Our single piece Kohler toilet does not flush clean. It appears to not be using enough water quick enough to give a clean flush. The tank level is just above the white line on the over flow pipe level so...
The flapper on these toilets is a water saver. The water saver flappers can be replaced with a standard flapper and I have found this will help considerably. The flapper is located in the tank at the center bottom. It is the part that flaps up and down when you pull the lever.
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 • Home
3helpful
2answers
My mansfield toilet 160 has a weak flushing problem
My toilet had same problem:
I thought it was a clog in the drain pipe.
But the problem was clogged holes where water flushes into toilet bowl.
Here's how I fixed problem.
Purchase:
Gallon of CLR calcium-lime-rust remover from Home depot.
Pumice stone from hardware store.
Home supplies:
Cut off bottom of empty clorox bottle to make container for CLR
Old 3" paint brush you don't use for anything else to apply CLR
Small cup to pour CLR into toilet flapper opening
Steps:
Look inside toilet bowl under rim and see holes where water comes out
Use brush and apply CLR to holes where water comes out.
Use pumice stone to scrape ... pumice stone will not hurt toilet surface.
Flush toilet to clear holes so far.
Turn off water to toilet.
Open flapper to drain tank.
Keep flapper open.
Use cup and pour dose of CLR directly into flapper opening.
(You can also pour CLR down overflow tube... but flapper opening puts whole dose directly onto problem)
Pour another cup of CLR into opening.
Notice how CLR starts coming out the holes into bowl.
Pour CLR down flapper hole until it runs easy and fast out of holes.
Close flapper, turn on water, toilet fixed.
Nov 22, 2010 • Home
Toto toilet does not flush properly - insufficient water to make it flush properly - need to pour water down toilet for it to flush. There is not any kind of blockage.
Check water level in tank for proper height it should be about 5/8 close to top of stand pipe in tank or it should have a mark on it wher it should be.
You can adjust the flush valve to increase water height.
May 13, 2010 • Home
1helpful
Toilet acts like it's getting pluged up as soon as you flush .
use a two gallon buck to flush your toilet - you pour the two gallons directly into the toilet bowl if it flushes fine you need to replace the flush valve, as it is not letting enough water through to properly flush the commode. either rebuild the flush system in the tank or install a fluid master and have a good nights sleep knowing that in the morning you will not leave a suprise for someone else in the family.
1helpful
When flushing toilet, water spins in bowl but does not flush away. Have used plunger to no avail. However, if I pour a 3 gal bucket of water into the toilet bowl, it flushes just fine and the water level...
Alot of times this problem occurs when there is not enough water in the tank behind the seat and bowl. Lift off the tank lid and see how much water is it, It should be near full.If it is not your problem is not enough water.
3helpful
2answers
Water comes from bottom of tank when commode is flushed. I have a two piece toilet, upon flushing it water pours from in between the two joined parts-tank and commode. I have the same problem. Water leaks...
Mar 29, 2009 • Home
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
