Anonymous Posted on Jul 03, 2013
2510 printer color of picture became dull
Anonymous
Level 2:
New Friend:
  • Expert 215 Answers
  • Posted on Jul 03, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
215
Questions
0
Helped
33976
Points
264
MAY NEED INK ALSO MAY NEED TO RE RUN ALIGMENT PAGE ETC
The pictures print but the color quality is horrible there's lots of blue, some colors are bright others are dull
i want to be rich why i can't see my own face why??????????????????????????????????????????????????????????????????????????????
My samsung ml 2510 wont print. seems to start up ok, although it had been taking a little longer to warm up recently
hello problem is your toner cartridge change the toner cartridge and try to print.then warming up is became ok.
Mirror or Misconvergance?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
My bottom part of tv to the left side became a little wavy and it's showing double and you can see also letteing in red color.
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dull colorless pictures
Have you made any changes to the settings? Check the ISO, picture quality (should be at highest setting), white balance, etc. You could also go into the setup menu and find the "reset" entry to reset back to default factory settings.
1helpful
Dull color
I would say phone or email Kodak as you may have a faulty printhead. If Kodak sayes you have a bad head they will airmail you one overnight and throw in free black and color ink tanks all free of charge.
I have read that some how in making the printhead a run got too hot in process and thus a bad printhead.
Hope this helps
Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
old marine
old marine
ZJ Limited
ZJ Limited
