Dometic ECD9K-HV 115V 9,000 BTU EnviroComfort w/ 417A Logo
Anonymous Posted on Jul 01, 2013
How do I trouble shoot this problem?
I had this unit installed on my sailboat 2 years ago. At the end of last season it quit running . The digital display no lights what so ever and the unit appeared completely dead was even considering replacing unit this year. Last week I was working on the boat doing some maintained which required some hammering in the vicinity of the thermostat display. I herd this clicking sound in yhe cabin so I went to investigate and found the sound coming from the a/c unit and three dots blinking on the display of the thermostat. I pushed the on button and then the cold button and the unit started and ran fine for about an hour. Then the clicking sound returned and lights blinking. Same procedure as above would start unit and it would run for various lengths of time then shut down and I would have to start the cycle over again.
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Jul 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
1626
Points
10
Sounds like a loose wire could be main power or in tstat
5 Related Answers
Anonymous
  • 95 Answers
  • Posted on Jun 25, 2008
SOURCE: Dometic Rooftop RV Air Conditioner
Possible bad capasitor, or seized motor
Anonymous
  • 51 Answers
  • Posted on Feb 17, 2009
SOURCE: Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Anonymous
  • Posted on May 18, 2009
SOURCE: Compressor will not come on. Fan runs great.
I fixed it. I had a dirty connection on the starter relay for the compressor. Thanks again for the help.
Anonymous
  • 127 Answers
  • Posted on Jul 04, 2009
SOURCE: My compressor will not start.
There are a few more things to try, in the control unit of the AC there is Cold Control/Freeze Switch. Take down the control unit (inside unit, remove inner shroud) and remove the cover, The freeze control is plugged into the blue plug on the board. Remove the plug and install a jumper wire in its place. Does the compressor come on? If so, you have a bad freeze control. If not, then we need to check and see if your AC power module is sending power to the Compressor. Check power across the relay in the control unit, Black to Blue. If the blue wire is hot, then you need to go upstairs to the top of the compressor and check the thermal overload. If the blue wire is not hot, the comfort control center may not be sending a signal to turn the compressor on. If it is not, do a reset of the CCC. For a five button system, turn the tstat off and hold down the Mode and Zone buttons simultaneously. While holding them down, turn the CCC on and hold the buttons until FF appears on the screen. Release the buttons and try the AC.
Four button reset -
Depress MODE switch to activate annunciator light.
Simultaneously depress the bottom two buttons
(temperature UP and DOWN) and hold.
While holding these buttons down, depress the
MODE button once and release.
Release the two buttons previously held down.
Depress the MODE button once again.
At this time the light should extinguish, and the mode
should register “OFF”. If not, repeat Steps 2 through
6.
Retest system ensuring that all functions are present
and operational.
Hope this helps,
Jeff
Rate me please!!
Anonymous
  • 334 Answers
  • Posted on Jul 19, 2009
SOURCE: Dometic Duo Therm Ac, Fan runs, Compressor cuts in and out?
your compressor is locked up. i would try replacing the round start capacitor. you need to check what the exact rating for yours is but I believe one of these two will work for ya. In the meantime do not continue to try to run it, it will kill the compressor.
seth
53-64 mfd
45-53 mfd
Why did my Hairer 8000 BTU portable A/C quit cooling on cool mode? It was working very well. This afternoon, I went into the bedroom, where the A/C is located, and room was not cool. When I switched t
Do you hear compresser start up noise. If so then please check it with a clamp meter and Amperage the Unit is drwing. If it is less than 8-9 Amps than there is some leakage in the AC and all the collent has leaked. So you got to get it serviced.
1helpful
We purchased a Heritage ceiling fan from our local K-mart about two weeks ago, we installed it today and it makes a VERY loud noise in the engine when we turn the fan on... We went through the trouble...
sorry but the company went out of business years ago. The only thing you can do is let it run, The heat from movement will warm the grease and dispers it. The unit is " kinda ceased " do to lack of sales, because there very low end.
Mar 11, 2011 • Garden
1helpful
I installed a Heat-n-Glo 6000GLX with wall mount control 4 years ago. Has been trouble free till this year. Actually problem may have started last year where the flame would light then flame out in 3-5...
sounds like your control module is defective, put you hand on the control unit and see if you can feel the noise.
Please Rate/Vote this response. Thanks
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I purchased 2 0520RLE airconditioners at cosco one has no hardwar
Contact the manufacturer explain your problem and they should send you the hardware you require.
Pilot flame moves off thermocouple when main flame
You must get the dust out of the ODS chamber that builds up during warmer months. If you go monkeying with the flap it will quit altogether. I use a simple squirt of rustbuster into the pilot, let it dry and all is well once more. You can get rustbuster at ace hardware for $2
3helpful
Stalls, with oil runing out the exhaust
you have a valve that is stuck in the open position head will need to be removed
then spray valves with wd40 and turn engine over a few times watching to see both valves open and closing,once that is working install head with new head gasket.this is caused by not properly storing the unit. gas should be drained at the end of every season and then ran to burn all gas off from carb and fuel lines once it quits remove sparkplug shoot a tablespoon worth of oil in the cylinder crank engine over for 10-15 seconds to distribute oil on cylinder walls and valves then re install plug now your unit is winterized ready for the next season
Jun 29, 2009 • Garden
Gas furnace cycles on then shuts down
COULD BE A ROLL OUT SWITCH ,OR GAS PRESURE TO HIGH TRIPPING ROLLOUT SWITCH COULD BE A FLAME SENSOR ,TELL ME MORE IF POSSIBLE
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
