I have an LG front load high efficiency washer and it won't spin & drain. I check the filter which was clean and there are no crimps it the discharge hose. The washer has run well for 3 months and now won't run.
Well, you have covered the usual reason for a no drain (and of course it won't spin if it wont drain because it's meant to stop the spin if there's water still in there). It sounds like the empty pump has failed. Can you hear it whirring on the empty cycle?
If you get under the machine and locate the pump, most have a fan-like assembly you can grab hold of and turn manually, occasionally this will free the pump up if it has something caught in it or the bearings are a little stiff. Next step is to remove it and clean it out, then run it on the bench and check it works. You will either fix it, or know that it's dead and have to get a new one at this point
