How do you light the pilot on a Vulcan convection oven?
You cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
SOURCE: vulcan oven will not stay lit
I would take out the pilot and clean it up and see what happens,also look behind the unit and see if theres a gas regulator on the gas line,if so you will see a nut on it take it off with a pair of pliers and clean as well.that valve is actually the saftey valve,when the pilot lights the flame impinges on the thermocouple and that sends a millivolt back to that valve in order to open.if none of these resolve your problem i would replace the thermocouple first as this is a cheap part and easy to put on.if you need a part # i can give it to you.let me know.
SOURCE: Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
SOURCE: oven will not light
Most
gas ranges currently available employ one of 3 basic gas ignition
systems; pilot ignition, hot surface ignition system (which uses a
'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition
system. The latter two being referred to as "electronic ignition"
systems as they use electricity in one form or another to operate the
oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems
and thus will not usually have a "pilot" which needs lighting. Be aware
though that just because the surface burners might light via a spark
doesn't necessarily mean the oven uses the spark type ignition system
too.
There is one older style of electronic ignition system which does
also use an oven pilot but it is very rare and such a system hasn't
been used in oven models since the early to mid 70's. It is the
'constant pilot' *electronic ignition* system
SOURCE: How to light Oven Pilot for Magic Chef stove 31000 PAW
There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
