Question about LG Washing Machines
Grease stains on clothes from LG washer (tromm 2688)
I have had 2 occassions where my clothes have emerged from my washer with grease streaks. I only use HE detergent, and have only recently begun using fabric softener. The first incident happened before I had ever used softener in the machine. My washer is approaching 2 years, and I do not have any mold or mildew smell. I did a tub rinse and routinely wipe out the rubber seal and leave the door open most times after washing. Could I be having an issue with the bearings or some other motor issue which causes grease to be released? It seems to happen at the end of the cycle because the deposits are streaked and don't look as if they were smudged from a wash/rinse cycle...any thoughts??? I am very happy with the washer in every other way and am hoping there is a simple/cheap fix... I was wondering why I get these dark gray spots on my Life Is Good tee shirts...I can only be coming from the washer. I have tried a number of cleaners, but none work.
  • LG Master
  • 2,529 Answers
Do a couple of tub clean cycles. Then do a quick wash with a cup of bleach thrown into washer on hottest setting. If you are using liquid soap, then switch to powder--no residue leftovers. Use max 2 tablespoons of detergent but only 1 1/2 is needed for full loads. Never use softener. If grease spots persist then I would guess bearing seal is the problem. Good luck.
Posted on Mar 09, 2017
4 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 210 Answers
SOURCE: grease stains on clothes from LG washer (tromm 2688)
If the problem was a bearing issue you would hear it. There is very little grease in the bearings, so I don't think that is the problem. It could be the fabric softener or maybe something that was left in a pocket. Try washing the clothes out again to see if it comes out.
I have heard of this on the dryer before.
Sgt 48
Posted on Jul 20, 2008
Anonymous
I have the exact same problem and I have NEVER used fabric softner. My washer is less than a year old. It is wiped down after each use, the door is left open, and we clean the trap out at least monthly.
Posted on Jun 23, 2010
Mech-NOT
Curtis Benham
We run a small hotel and have been having this same problem with our LG Direct Drive WM2301HW... but the stains aren't grease at all... they're from sledge buildup in the washer. I found this out when I cleaned the lint trap behind the small door at the bottom left, on front of the machine. I ran my finger around the interior and found it lined with black, stinky muck. Due to the low position of the filter, this area never fully drains, so the muck collects and the bacteria grows. Of course, this means the pipes or hoses to the filter are probably also lined with this muck.... Poor design!!! Try running the washer empty (no clothes) with a couple cups of honest to goodness chlorine bleach. Then run it again to make sure all the stuff that came loose gets pumped out.
Posted on Dec 21, 2012
My LG Front Load washing machine is leaving black streaks and smudges on my clothing. These streaks and smudges are ruining my clothes!
There can be several things that can cause this problem. The most common are:
1. Fabric softener - did you switch brands lately?
2. Chlorine bleach - if added at the wrong time
3. A mechanical problem with the washer, like a leaky transmission leaking oil.
4. Rust staining, sometimes caused by the water being used in the machine.
Here is a link to a site that discusses this issue more in depth:
http://www.stain-removal-101.com/washing-machine-stains.html
Jul 26, 2015 | LG Washing Machines
My washer stains my clothes. it looks like grease stains on delicate fabrics. plse advise. I checked many times and dont know where it is coming from. agnes
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Clothes have dark streaks after washing this is a kenmore front loading washer model number 417.42142100
I read post after post about this very same problem, it is caused by a failure of the bearing that the tub rides on, this causes the grease seal to leak and then the streaks which are grease stains from the rear bearing
Jul 07, 2010 | Kenmore Washing Machines
Sometimes there will be grease streaks on the clothes after wash.
the main bearing and seals on the drum side are faulty. this should be under warrenty
Dec 29, 2009 | LG WM-2077C Front Load Washer
Clothing stains
Get a flash light and look very closely at the entire inside of the washer. what you are looking for is a little yellow grease, which is causing this problem. if you find the grease, remove it with a degreaser and you will be fine.
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Dark Grease stains on my Kenmore Front Loading washer
THE SEAL IN YOUR TRANSMISSION IS GONE. NEEDS TO BE REPLACED.
Dec 13, 2008 | Washing Machines
Clear greasy stains appearing on clothes from brand new LG front loading washer
the grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
drcool
Sep 28, 2008 | LG WM2487H Front Load Washer
Jul 16, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm Front loader won't remove stains
Try using a stain remover to see if that will help. Sometimes tough stains need a little help.
Sgt
May 11, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
832 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
