Microwave Ovens Logo
Anonymous Posted on Mar 26, 2009
Microwave Oven Door Spring Replacement
I have a KitchenAid Superba Oven Microwave Combo. The microwave door spring broke. How do I replace it?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2129
Points
8
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
  • Anonymous Aug 01, 2012
    do not no how to put spring in
How to change the torsion springs in my kitchenaid microwave oven KEMC308KSS01
Replacing the spring isn't very difficult if you're mechanically inclined.
You're basically removing a few screws, the front panel of the door is removed exposing only the glass part that's still hinged. The springs are exposed. Hopefully one spring is still in tack so you can see the orientation of how to put the replacement in. It's not very intuitive on how to do this part.
Check this link for more details:
Microwave Repair
tip
Maytag MMV4205 door won't stay shut.
After tearing apart my microwave, I found a little spring broke off the latches. Open the door to the microwave, pop off the plastic piece that the latches on the door go through. You will see a spring behind the latch. If the spring is not connected to the latch it won't operate properly. The spring was held onto the latch with a tiny plastic piece that broke off. An easy solution instead of buying a new latch is to heat up one side of the spring without burning yourself and melt it through the latch piece where it was originally connected then put everything back together.
Hope this helps,
Pillarair
Door spring on build in microwave oven
Is this a combination built-in oven with microwave on top? And is this microwave one in which the door opens downward like a regular oven? If so, then this is a common problem for this oven/microwave combo, but replacing the spring is not a job for amatures. It takes a professional 45 minutes typically to do this job. It involves removing trim pieces, removing screws that hold the microwave oven in place, pulling the microwave out a couple of inches, and taking the door apart to get to the 2 torsion-bar springs. Replacing them is quite tricky, as is re-assembling the door. I recommend calling Sears Service (1-800-469-4663) to get a seasoned repairman to come out and fix your oven/microwave. Cost will probably be between $180 to $200.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
How to replace torsion spring in the microwave door
If this is the flip down door. You will need to take apart the side cover of the unit to fasten the spring. Once you have done that you need to put a pen or something to hook it so it doesn't drop down in the unit. If you are unable to hook the spring in the door. You must take the outer cover off the door to hook the spring and then replace the cover. You may find this to be a two person job and may be easier to hook the door before you hook the unit. Some doors are different then others.
Latch opener spring broken wont open door
You can buy a new door spring through KitchenAid by calling For more information on warranty replacement, please call 800-541-6390
that should solve the issue if not feel free to contact me.
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Microwave door tension spring
See answer here http://www.fixya.com/support/t265705-microwave_door
in different thread.. Basically have to pry plastic trim ring off inside of door with putty knife (careful, it cracks easily) to get to screws on bottom of door. See second pic. Top screws are easily accessible from inside of door. Spring can easily be replaced by hand once you get adequate access. You'll need a fairly stubby right angle screwdriver (I used a cut-down #2 Phillips bit and small Vice-Grips as a make-do) to get to the screws. Also need Torx (T10, I think) to detach the shock absorber doodads from the door where they attach above the hinges. If you're just starting to take the door apart, be careful when you take out the top 2 screws on the inside-- they hold the inside plastic piece on , but they also hold the whole outer stainless/ glass/ handle piece on. It just slips in at the bottom, so be ready to slide it out when you take these screws out.fea33aa.pngc391898.jpg
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
