Weed eater will only crank and run on full choke idled way up. Also, upon cranking, the trimmer head just starts spinning all out, without me ever touching throttle. When idle down, touching throttle makes it die. No power, lots vibration, and free spinning trimmer gead without touching gas?? New air filter. Fresh oil and gas. New carb last summer. New fuel lines.
SOURCE: Weed eater GTI 17 won't run on high speed
A couple of things may work...
Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
