Exercise & Fitness Logo
ron eason Posted on Jun 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E5-5 error code on Treadclimbe
Getting E5-5 error code on our Nautilus Treadclimber TC5000. Not sure what it means or what we need to do. Thanks for any help you can provide.
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Jun 20, 2013
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4075171
Points
34431
Follow the steps and fix it. God bless you
The power up test sequence has detected a key in the operated condition. The power up test
sequence is performed every time the unit is turned on (powered up). This test is performed
because a permanently stuck key will inhibit the correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck in the operated condition.
2. One of the upper PCA's keypad interface chips has failed.
3. Liquid (perhaps perspiration) is present on the surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the cause. The keypad is typically part of
the display housing. Replace the display housing to correct the problem.
2. Remove the keypad connector cable from the upper PCA. Restart the power up sequence, if
the ERROR 5 is still present, the upper PCA is the cause. Replace the upper PCA to correctE5-5 error code on Treadclimbe - c3d2efcd-4214-4aa4-b3ad-6b1e2ccdbf44.gif
2 Related Answers
Anonymous
  • Posted on May 30, 2009
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Nov 19, 2012
SOURCE: TREADCLIMBER tc5000 error code e5_5
see the steps and fix it. God bless you
Error 5
Description
Possible Causes
Possible Remedies
I have a Nautilus Treadclimber TC5000. I believe it is the same as the Bowflex machines. How do I change out the rear roller assembly from the two rear rollers it has to the single roller replacement? Do I...
did you need help finding the manual? All we would do is access the manufactures website search for your item and obtain the manual- after we would furnish you the results as per the manufacture. Most companies do not support comparable parts only authorized- How can I get this question closed? What can I provide you?
good luck
https://www.6ya.com/mrmmike
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458
In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual
Good Luck!
2answers
Thanks for calibration tip. TC5000 Nautilus. Any ideas with a "no speed sensor" error?
If you are getting a speed sensor error it usually means that the sensor has died. Try getting ahold of Nautilus to see if can get a replacement. Funny thing is that Nautilus is headquarted in the town i live in and from what i hear they have great customer service because they have happy employees.
If you have a multimeter or a light tester test the power wires to see if power is going to the sensor. If you have power going in it means that the sensor has died.
5helpful
Nautilus tc5000 treadclimber has e5 error. Will run for 5 seconds, then stops. Thanks
The E5 error code indicates the electronics on your treadmill require calibration. Recalibrate the machine per the instructions in your manual to clear this error code.
E2-C error code
you must be steping on the machine for the generator to allow you to set its functions , keep steping until you have entered in your requirements and weight and workout that you would like to have ,this will allow your programming also to be saved ,also see if you have battery backups on this model ,they can be dead ! , hope this helps thanks glenn
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
