Question about Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer ()
Craftsman gas trimmer model 358797150
HOW TO PROPERLY WIND STRING IN SINGLE HOLE COMING OUT OF SPOOL HEAD.I KNOW THE ROTATION.I HAVE VIEWED THE MANUAL ONLINE STILL CANNOT FIGURE OUT THE THE RIGHT ROUTE OF STRING PLACEMENT ON THIS OLDER SPOOL.I HAVE TRYED SEVERAL WAYS AND STRING JUST COMES RIGHT OUT OF SPOOL WHEN RUNNING.DOES ANYONE KNOW A GOOD PLACE TO LOOK AT SOMEONE SHOWING THE EXACT WAY? TY
    Top Expert:
  • Craftsman Master
  • 66,497 Answers
Try YouTube
Posted on Sep 27, 2017
5 Suggested Answers
Mike Squire
  • 420 Answers
SOURCE: i have a string craftsman weed wacker an the
Turn the big knob on the bottom LEFT to loosen it in order to access the drum with the line on it.
Posted on Jun 04, 2010
2strokeguy
2strokeguy
  • 183 Answers
SOURCE: I received an answer for a 25cc gas trimmer,
The routing of the fuel lines is the same. If you have 3 lines, that means the primer bulb is not directly mounted to the carb, rather it is connected to the carb with hoses.
Line 1. Comes from the fuel filter in the tank (smaller diameter hose) directly to the inlet port on the carb. This is the port that is opposite the diaphragm on the carb. Diaphragm is held on with 2 or 4 screws through a chrome plate. Make sure to leave enough hose so the fuel filter will fall to the lowest point of the tank when it is being used.
Line 2. Goes from the other port on the carb to the short side of the primer assembly.
Line 3. Goes from the longer port of the primer assembly and returns to the tank. Sometimes this line will have a simple coupler on the inside of the tank, but it is optional and its only function is to keep the line from slipping out. If yours does not have this coupler, just leave an inch or two of line in the tank.
*If both ports on the primer are the same length, you can test to see which is pushing air out...that's where line 3 goes.
Posted on Oct 15, 2010
danny Hendrickson
  • 2468 Answers
SOURCE: I need to know the
38:1 gas/oil mix,but not less than this amount
Posted on Mar 22, 2011
nfsmith
SOURCE: How do I remove the hassel free head of my
I can get you part way there. Remove the spark plug and shove some clean rope in the cylinder to prevent the engine rotating. Take the front housing off to access the clutch assembly, pull off the black plastic cover from the shaft end, and use a torx wrench to loosen the screw in the end of the shaft. After it's loose, the clutch drum will come right off. Unfortunately, I am stuck now trying to get the rest of the clutch assembly off without damaging it.
Posted on Apr 25, 2012
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: how do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
Posted on Jul 19, 2015
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
Jul 19, 2015 | Craftsman Convertible 25cc. Gas Line...
I inherited a Ryobi 14'' Electro Hornet, but do not know how to change the trimmer line - can you help?
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Nov 29, 2009 | Ryobi Garden
Stihl fs trimmer line fitting how to fit line to trimmer can you help anyone
If you need more help, let me know.
Jim
Nov 20, 2009 | Garden
NEED INSTRUCTION SHEET FOR LINE INSTALLATION
Jim
Oct 25, 2009 | Garden
How do you remove the line feed to replace with new. Is is scred on or does it have a lock washer
It should be screwed on. There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
Jim
Oct 17, 2009 | Craftsman Convertible 25cc. Gas Line...
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
How to change the string
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you wind replacement line to the Poulan Pro String Trimmer?
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How do I replace the line on the spool?
Jim
Jun 27, 2009 | Garden
How to add more line in my craftsman 32cc
Invert the trimmer pull the center of the head straight off. Wind new line in counter Clockwise direction. There should be a hole or notch to place the center of the string in. insert each end of the sting through one of the holes in the head and reinsert the spool into the proper position. Be sure that the automatic advance is movable by pressing down and pulling out more string. Cut string to proper length and restart your trimmer
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 27cc 2 Cycle Crank Straight Shaft Weedwacker Gas Trimmer () Logo
Top Craftsman Garden Experts
john h
rjivaro
Marvin
Marvin
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
