Hello to all i have asus ac46c, accidentally during restart i press key f9, instead of f8 foe safe mode.. and now my laptop only bios menu affair after on, even i try to restore bios setting, even i flash the bios to latest version.
SOURCE: How to remove BIOS memory cache
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
SOURCE: Hp laptop keeps restarting. I have tried f8 to go
Select Last Known Good Configuration instead of Safe Mode.
SOURCE: Set my Toshiba Satellite Laptop PSA60U-01W015 to it Factory Sett?
some of these systems have the factory restore option on post boot before the OS kicks in. From a cold boot look for the hit DEL or Fx key and do that - you may have to boot a few times to catch it, and possibly hold the defined key down in anticipation of the option to appear on what looks like a DOS screen. You may need the recovery discs that came wit the system if the image is not in a hidden partition of your drive. Good luck.
SOURCE: My laptop wont exit safe mode even when pressing
this is a case of os corruption somehow..!!..may b a virus/trojan or hardware or software is responsible..
all u need is the os boot cd anyway..
probably now u got two way out:
goto somecyber n download win xp pro sp2, using any bit-torrentclient(like utorrent) from torrent site (eg. mininova.org so on)..make aboot disk n try..
1) copy the file in windows repair mode or from any identical os n put it in place as stated above..
OR 2) reinstall os..
(to takedata backups u gotta connect the hdd to another pc/laptop, forsuch cases a hdd-case is available in the local spare market, it'llmake behave ur hdd to act as an external removable drive)..
thiscan also b a symptom of faulty/defective of RAM..pen clean/removecarbon& or oxide formed on the teeth with an eraser n resitit..[it'll b more prominent, that if itz cause by ram or not,..if duringnormal operation, a Blue Screen appears/Memory Dump]
though, sometimes itz also caused by the m/b..
there are also exceptions, where it is found that any hardware componenton the system is loose or incompatible (see addon cards, the ram(s),the hdd (if itz making any 'ticking' noise like 'kirr kirr' or 'tuc tuc'), all data cables n power cords, may b dusty, cpu overheating,see filter/power/south bridge/crystal clock generator section of m/besp mosfets and capacitors..etc)..
if once u can login, do the following:
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, , without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessarystartup items from here..(if u can't find what to remove,post me/us inur comment with all the items listed in each n every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disablethe following: a) 'Automatically Restart' right click on mycomputer->properties->advanced->startup n recovery->(uncheckon the) Automatically Restart; b)'Error Reporting 'right click on mycomputer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when critical erroroccur'..
Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
always better to seek professional advice of ur system admin/vendor....
SOURCE: Dell D600 wont go into bios mode
Hi ,
if you wanted to get the bios setup you have to press Fn+F1 then you will go to the bios setup
and my other problem there is no boot option on bios...like cd rom or hdd..
but my hdd ang cd rom is detected on bios
