Follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel,
the heating element might have burned out. The heating element heats the
water up to operating temperature. After a set amount of time if the
temperature isn't reached a light on the control panel might start
flashing. The heating element can be checked for continuity with an Ohm
meter.
Heating Element Assembly
the heating element assembly might have burned out. The heating element
assembly heats the water up to operating temperature. After a set amount
of time if the temperature isn't reached a light on the control panel
might start flashing. The heating element assembly can be checked for
continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there
is an error code in the display window, check the wiring diagram and
tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
the drain pump might not be working properly. For two-wire drain pump
motors check them for continuity using an Ohm meter. If it's defective
You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the
entire touchpad and control panel assembly might be defective. If the
display works but the dishwasher functions are all out of synch, or some
of the buttons don't respond properly the entire touchpad and control
panel might need to be replaced.
Touchpad
If the display lights are flickering for no
reason, the touchpad might need to be replaced. Sometimes when the
touchpad is defective the display lights are flashing randomly.
