Question about Frigidaire GLTF1670A Front Load Washer
Front load washer
The fabric softener dispenser no longer works on my frigidaire front load washing machine. We have tried removing it, cleaning, soaking,.etc.
  • 6,784 Answers
HI. your model has a dispenser solenoid for the fabric softener dispenser on this unit. If the solenoids are out or malfunctioning, it will render the dispenser useless. i recommend checking the solenoids on the fabric softener dispenser for continuity. The resistance should be 1100+- 7%. replacing this blown solenoid will fix this issue. Remember. the dispenser valve will not function without a working solenoid.
please rate and god bless.
Posted on Mar 22, 2009
Anonymous
SOURCE:
How do I get the fabric softener dispenser to keep from filling with water?
Remove dispenser and clean the drain hole from under neath try with q tip.sounds gunked up.
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
The fabric softener dispenser will not empty on my Frigidaire FTF530FS.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Feb 24, 2011 | Frigidaire FTF530FS Front Load Washer
Water in fabric softener dispenser
you will need to clean out the tray thoroughly and then remove it to clean out the holes above it with a stiff washing up brush. these get blocked up and dosnt help force the fab cond out.
Mar 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load fabric softener dispensing
Try to clean it out. Pour very hot water over it. It's probably just gummed up. This happens. Is it a drawer type thing. Remove and soak if possible. I need more information before I can help you further. Model, Brand etc.
Jul 03, 2008 | Frigidaire GLTR1670A Front Load Washer
Fabric softener will not dispense
My wife reported the same problem and I took the top off the washer (2 screws at rear of washer and top slides forward) . Under the top on the left front side behind is the dispenser. On the top is a click adjuster similar to a clock hand pointer and in the center is a tick mark and off to the left side is (-) marks for reduced dispensing and to the right (+) marks for increasing dispensing. I moved the pointer all the way to the plus side and after a few loads the dispenser works fine. I assume over time the different fluids (fabric softener, detergent, etc) tend to gum up the valve mechanism. If this doesn't work I would try pouring some very hot water in it to try and loosen things up. After you try all the free thing, I guess the last option is a new dispenser.
Apr 06, 2008 | Frigidaire FWT449
water remaining in the dispenser is normal doesn't mean its not dispensing consult your owners manuel
Jan 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
811 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
