Question about Kenmore Elite 45986 Front Load Washer
Torn seaL ON KENMORE ELITE WASHER
I havea front load kenmore elite washer with a torn seal in front ,i have bottom front cover off ,but i dont know how to remove center cover with door off
I have a kenmore elite washer the red lite is lit on controlles locked how do i solve this
Posted on Mar 23, 2009
6ya staff
SOURCE:
How do yoou remove front bottom panel on a kenmore front loader
You remove the lower panel just under the door by removing 3 screws under the curved part 1 each corner and 1 center, once that is done you will have only min working room,\.
Apr 01, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he washer lock light. cannot open
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Thank you !!
May 31, 2010 | Kenmore Elite 45986 Front Load Washer
The boot seal/tub seal is torn and I want to replace this piece
door boot or baffle as it is sometimes called can be replaced. however it is not an easy job as there is a large spring that hold it on.
Oct 04, 2009 | Kenmore Elite 45986 Front Load Washer
Removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Door Seal
Just follow this link and it will explain how to replace the door seal:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is a very simple repair, if you follow the step-by-step instructions. Take your time and if you have questions, let me know. I hope this helps you.
PS An alternative method is to work through the door with the front panel in place, but this limits access. To make things easier, it is strongly recommended that you remove the front panel.
Apr 13, 2009 | Kenmore 42822 Front Load Washer
Torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Het3 elite
remove the bottom panel below tha door. youll see the drain pump in the center,fronr of washer. there is a black hose going from the pump to the bottom of the tub. remove that hose. at the end of the hose there is a plastic ball that is supposed to seal the end of the hose. more than likely there is lint build up on the ball or around where the ball seal. clean the ball and the hose and reinstall. you should be fine after that
Nov 27, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
609 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
